optimal shift point???
I searched and no answer. I have a bone stock usdm 2000 h22 and I was just wondering were the power band lies in my car. At what point will my cams stop making power?? Whenshould I shift? Also what is my redline??
shirt right before 8k when going from 1st to 2nd to keep it in vtec, after that you can **** around 7200 because you aren't going to make power after that and shifting at 7200 after 1st gear you can keep it in VTEC
take it to redline in each gear.
if you REALLY want to figure it out, dyno your car. the shift point is that which the Torque multiplied by the total gear ratio drops down to equal or below the torque multiplied by the next gear ratio at the RPM you will be at at that speed in that next gear.
OK I found some answers when I searched under "shiftpoint". BUT I forgot to mention that I have an h23 trans. Will this adversly affect my shifting or can I continue to shift as if I had an h22 trans??
h23 gears are longer. you will need to dyno your car. everyones shift points are different anyways, its just like asking where to set vtec. we can give you a ruff estimate, but nothing as good as actually spending the money to get your car dyno tuned.
pmachan
Jan 19, 2006 11:45 AM
blackrex
Mar 18, 2005 05:37 PM
