Cel codes/resetting ecu
Old Sep 26, 2004 | 07:40 PM
dj626's Avatar
Default Cel codes/resetting ecu
I have done a search and didn't come up with much of anything useful. Hoping someone can either link me, or expain to me how I reset the ECU and how I pull a cel code on a 1998 honda prelude SH. Thanks.
-I tried to pull the neg cable and it didn't reset the cel, also read that there is a fuse behind the main relay under the hood on the passenger side but I am not seeing that on my fuse diagram.
Old Sep 26, 2004 | 07:46 PM
delguiner's Avatar
Default Re: Cel codes/resetting ecu (dj626)
You have to unhook the battery for more than 10 min...
Old Sep 26, 2004 | 07:58 PM
dj626's Avatar
Default Re: Cel codes/resetting ecu (delguiner)
More than 10 min? Ok I suppose I will try that one. Anyone else? I'm pretty sure that it's just a regular maintenence code as I just hit 90k and it came on, but I just want to be sure. Thanks again guys.
Old Sep 27, 2004 | 03:17 AM
preludeez's Avatar
i unhook the battery and pull the fuse to the ecu when i'm resetting it
Old Sep 27, 2004 | 07:04 AM
Mr.Dew's Avatar
Yep, it's Eric.
Default Re: Cel codes/resetting ecu (preludeez)
do it in this order:
undo neg. terminal, wait 10 seconds, pull ecu fuse (clock/radio under hood), wait 10-20 seconds, put fuse back in, put neg. back on.
Old Sep 27, 2004 | 07:55 AM
kellyk75's Avatar
Default Re: Cel codes/resetting ecu (oNeMoBB1)
https://honda-tech.com/zerothread?id=682412
To reset the ECU, JUST pull out the clock/radio fuse under the hood for 10+ seconds. Why would anyone remove the neg on the battery?!?!?!?!?!
Old Sep 27, 2004 | 08:06 AM
98TypeSH's Avatar
Default Re: Cel codes/resetting ecu (kellyk75)
i remove the neg on the battery and then went and got something to eat. Came back fired her up, and the CEL i fixed was gone w00t.
Anyway. You need to fix the problem before the CEL will go away.
Fix the problem, reset ECU, start the car.
Old Sep 27, 2004 | 12:16 PM
dj626's Avatar
Thanks for all the info guys.
Yes, I know I need to fix the problem to get the cell completely fixed rather than having to reset the ecu as a temporary solution, well not really a solution just so I don't have to look at that damn yellow light, which is why I was wondering if any one can tell me now to check the code for the cel.
-Thanks for the link kellyk75
Old Sep 27, 2004 | 12:25 PM
98TypeSH's Avatar
here j00 go. Im sure searching on this site would yeild a similar result
http://hondaprelude.to/article....html
Old Sep 27, 2004 | 12:38 PM
dj626's Avatar
Default Re: Cel codes/resetting ecu (98TypeSH)
Exactly what I was looking for, thanks.
Old Sep 27, 2004 | 03:31 PM
Mr.Dew's Avatar
Yep, it's Eric.
cuz you can short out your fuse if you don't remove the negative.
greeen ranger
Jun 16, 2013 06:38 PM
98GSRrdr
Mar 20, 2007 11:17 AM
CPR
Aug 21, 2003 09:04 AM
Hybrid 350GT
Jan 18, 2003 03:02 PM
Bbasso
Jan 1, 2003 03:21 PM
