Check Engine Light / ABS Light
Old Sep 23, 2004 | 12:22 AM
JDMF22B's Avatar
Default Check Engine Light / ABS Light
K well i just got a f22b swap done tonight, the guy who worked on it thinks there might be something wrong with the O2 sensor because the check engine light just pops on for no reason (if u restart the car, its gone). Same with the ABS light. Anyone know what could be causing this?
Old Sep 23, 2004 | 12:25 AM
esca's Avatar
Default Re: Check Engine Light / ABS Light (JDMF22B)
wiring.. i used to have the same problem.. the o2 sensor wiring kinda died out.. and then it shorted HELLA fuses.. didnt know what was wrong until i found the saggy o2 wire touching my axle
Old Sep 23, 2004 | 01:18 AM
Cashis Lee's Avatar
Default Re: Check Engine Light / ABS Light (esca)
Did you try pulling the code to see?
1slowcrx
Dec 6, 2011 04:51 AM
1slowcrx
Dec 5, 2011 01:30 PM
Corporation
Aug 21, 2005 08:55 PM
RDSDC2
Nov 24, 2004 12:04 PM
huepowered
Jul 6, 2004 06:16 AM
