H22 problems Need Help
Old Sep 22, 2004 | 04:49 PM
1point7db2's Avatar
Default H22 problems Need Help
I need help figuring out some issues in my H22 CRX, I got the car already swapped, and I dont know much about H-series motors. When I got the car it was throwing 2 codes IACV and CYP. I fixed the CYP by wiring it sraight to the ECU. I couldnt figure out the IACV. Sometimes the cr wouldn't start unless I hotwired the fuel pump, then I could remove the wire, and it would start fine for a while, then same problem again. Then I threw an oxygen sensor and a fuel injector code. I reset the ecu and I just had the IACV code. I was driving one day and the car went into "limp mode". I reset the ECU and it was still in limp mode but wasn't throwing ANY codes. Now it wont start at all and its really frustrating because this is my only car.
onefastek9
Jun 26, 2008 12:35 PM
H22Ej2
Aug 14, 2006 06:01 PM
1point7db2
Sep 22, 2004 03:24 PM
1point7db2
Sep 21, 2004 03:08 PM
