Question...
Old Sep 22, 2004 | 07:43 PM
Slipknt777's Avatar
Default Question...
I have a JDM H22A swap. I have i/h/e gude cams, pulleys. I know that vtec doesnt kik in until it is warmed up. But anyway i started out in first and a lil bit before 7k it felt like the motor shut of for like 1/2 a second right before i shifted. But when i shifted it went fine into second and i kept on goin and it seemed like nothing has happened. the redline for my cams are 8600 but i didnt get close to that. What would cause that to happen?
Old Sep 22, 2004 | 07:52 PM
Slipknt777's Avatar
Default Re: Question... (Slipknt777)
i think i may have stumbled upon it...i wasnt sure what to search for but i think i found it in a post. I appologize to the mods. tell me what you think?
Quote, originally posted by jmcclell »
The ECU limits the RPM at 6500 RPM with no VTEC for 3 possible reasons:
1. It thinks the coolant temperature is below 60oC. (engine cold) (ECT sensor)
2. It thinks the car is doing below 20kph. (car stopped) (VSS)
3. It thinks the VTEC solenoid coil is bust.
The VTEC control wire comes from A4 on the ECU connector and is a GREEN/YELLOW wire.
Hope this helps.
Modified by jmcclell at 12:28 AM 9/22/2004
4)it's not getting a signal from the VTEC Pressure Switch...
BlackoutVTi
Jun 12, 2008 12:30 PM
IVAN93EG
Jun 18, 2006 07:02 PM
abolish415
Jan 24, 2005 09:54 PM
4bangin
Oct 4, 2003 06:53 PM
davken1102
Aug 2, 2003 06:01 PM
