iab
Old Oct 10, 2004 | 12:27 AM
Monkey Fing a Coconut's Avatar
Default iab
is the iab the same thing as the secondary's, and if so, are they the same thing as the by-pass control solenoid valve shown below
thanks
Old Oct 10, 2004 | 12:34 AM
blackdelslo's Avatar
Default Re: iab (twistedbydezign)
Yes its Intake Air Bypass(secondaries) which is composed of #12 and by-pass control solenoid valve, check valve and also the solenoid.
Sorry to jack your thread but on a prelude where does the starting air valve mount?
Old Oct 10, 2004 | 12:45 AM
Default Re: iab (delLudeVTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by delLudeVTEC &raquo;</TD></TR><TR><TD CLASS="quote">Yes its Intake Air Bypass(secondaries) which is composed of #12 and by-pass control solenoid valve, check valve and also the solenoid.
Sorry to jack your thread but on a prelude where does the starting air valve mount?</TD></TR></TABLE>
thanks for the reply, for the starting air valve/air boost valve, if u look at the diagram above, where its positioned on the diagram is the same as if u look at the IM, if u have a jdm IM, then there is a plate that blocks off where it would go
F20Cdriver
Feb 21, 2015 07:55 PM
JDM_SOHC
Mar 28, 2009 01:58 PM
DeDonDeRosa
May 2, 2006 11:30 AM
