Possible clutch problem?
Old Oct 7, 2004 | 05:41 AM
DarkShadow's Avatar
Default Possible clutch problem?
When i shift into Reverse or 5th, i often hear a loud crunch coming from somewhere in the front of the car....after i shift out of R or 5, and shift back in, the crunch is quieter. Sounds to me like something is grinding...maybe some built up dirt or something? any ideas...thanks.
Old Oct 7, 2004 | 04:18 PM
DarkShadow's Avatar
Default Re: Possible clutch problem?
anyone?
Old Oct 7, 2004 | 04:28 PM
GaRn's Avatar
Default Re: Possible clutch problem? (DarkShadow)
change your transmission fluid to Penzoil/GM Synchromesh...
your 5th gear sprocket/sychros is a little worn or you might just need to change your flluid.. I know when I got my lude it wouldnt let me shift above 5000 rpms b/c the fluid was so worn out/old...
Old Oct 7, 2004 | 05:24 PM
DarkShadow's Avatar
Default Re: Possible clutch problem? (GaRn)
i figured it might be my fluid. thank you much.
avargas28
Aug 2, 2011 04:19 PM
arielb1
Dec 12, 2009 01:34 PM
04civicex84
Transmission & Drivetrain
Dec 8, 2008 08:52 AM
AwOrKiNpRoGrEsS23
Aug 29, 2006 11:19 AM
hb_racer
10
Mar 14, 2002 02:36 PM
