Tail lights MOD
Old Feb 14, 2005 | 08:01 AM
mraza's Avatar
Default Tail lights MOD
Hey... Anyone have any info as to how to do this Tail light mod????
http://www.superhonda.com/phot...t=506
also if anyone would be able to do it for me????
thanks
Old Feb 14, 2005 | 08:04 AM
Greyout's Avatar
Default Re: Tail lights MOD (mraza)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mraza &raquo;</TD></TR><TR><TD CLASS="quote">Hey... Anyone have any info as to how to do this Tail light </TD></TR></TABLE>
you will need to obtain a bunch of LED's, circuit board or something equivelent, soldering iron, and skill with said tool.
Old Feb 14, 2005 | 09:46 AM
9deuce9rr's Avatar
the circuit board isn't 100% neccessary, but it makes a much MUCH cleaner result and is a lot safter. you are going to have to be fairly skilled with a soldering iron tho if you want it to last more than a couple weeks. you can find the LED's pretty cheap on ebay.
if you decide to do it, it will be very time consuming and very tedious work.
Old Feb 14, 2005 | 11:16 AM
The Phil's Avatar
Default Re: Tail lights MOD (WhiteLude)
its pretty simple. Just get all the LEDs soldered in and make sure you have resistors wired in series so the LEDs dont burn out. Personally, i'd put one resistor per vertical line of resistors, and run each vertical bank in parallel off your power source (which would be the power to the brake lights)
Little bit of electrical knowledge and a whole lot of time...shouldn't be hard though.
jaywoodz
Feb 10, 2007 11:55 AM
HondaTech101
Dec 28, 2006 08:30 PM
neeks
Jun 10, 2006 10:49 PM
downeTOmarsGIRL
Jul 27, 2004 10:33 AM
krnboixshawn
May 22, 2003 03:42 AM
