Throttle Help
Old Feb 14, 2005 | 09:54 AM
RA61825's Avatar
Default Throttle Help
How do i take off the throttle cable off the gas pedal . im putting on a new one and i disconnected from the throttle but i cant take out the cable
Old Feb 14, 2005 | 10:04 AM
Greyout's Avatar
Default Re: Throttle Help (RACERX72)
crawl down to the floorboard and look up at the gas pedal.
Push the pedal all the way down with your hand, which will put slack in the cable. The little **** on the end is rotated around so the wire will slide out of the groove, pretty much the same way as the throttle body end.
The cable goes through a plastic grommet in the firewall. Twist this 90 degrees, and then pull out.
hope that helps.
smc1118
May 5, 2014 04:55 AM
slacks
Sep 20, 2008 09:49 AM
91da9ls
Jan 29, 2007 04:00 AM
19992civichatch
Jan 10, 2007 06:27 AM
rolledthatho
Sep 9, 2005 10:29 AM
