lowering methods.
Old Feb 12, 2005 | 01:25 PM
ingy's Avatar
Default lowering methods.
im looking to make my car a few inches lower however it cant be to low to the ground cuz i g2 get over the speedbumps at school and it cant be 2 expensive. i was think coilcovers and ive found some for around 200$ any cheaper methods or choices??
Old Feb 12, 2005 | 01:27 PM
5hif7's Avatar
Default Re: lowering methods. (ingy)
suspension is not something you wanna go cheap on. Save up some more money and get springs and shocks
Old Feb 12, 2005 | 02:22 PM
clemsoncb7's Avatar
Default Re: lowering methods. (5hif7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 5hif7 &raquo;</TD></TR><TR><TD CLASS="quote">suspension is not something you wanna go cheap on. Save up some more money and get springs and shocks</TD></TR></TABLE>
Good call, don't ever skimp on it because you will have the shittiest ride ever. Especially if you use coilover sleeves on stock struts, BAD IDEA! Save up for some eibach sportlines and KYB AGX's or something, just don't go cheap. Good luck
Old Feb 12, 2005 | 02:37 PM
92SleeperH23's Avatar
Default Re: lowering methods. (maxvtec7500)
Some of the idiots around my school chop their springs, trust me, don't do this. Once it's cut, it's cut, and just because all springs are cut the same doesn't mean they'll drop the same...it looks weird on my friend's Accord where the *** is sagging, plus you get a really shitty ride like this.
Just sayin' before anyone offers it as a solution, NOT to do it.
Old Feb 12, 2005 | 04:05 PM
LeafBoy's Avatar
dont coilovers cost like $1000
Old Feb 12, 2005 | 08:41 PM
prylwd's Avatar
Default Re: (LeafBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LeafBoy &raquo;</TD></TR><TR><TD CLASS="quote">dont coilovers cost like $1000</TD></TR></TABLE>
For any good brand like tien's yes.
Old Feb 12, 2005 | 08:44 PM
BS 22's Avatar
you can find some ebay coilovers for real cheap.
same with ground control and skunk2. i think they only go for 200 im pretty sure.
Old Feb 12, 2005 | 09:08 PM
dohcvtecpower's Avatar
Default Re: (BS 22)
you could just get some tein s-tech springs they dont cost that much.....
Old Feb 12, 2005 | 09:25 PM
The Phil's Avatar
Default Re: (dohcvtecpower)
you get what you pay for. save up and get good coilovers.
Old Feb 12, 2005 | 11:43 PM
bad-monkey's Avatar
custom rate ground controls + koni yellows.
if you can't afford that, custom rate GC's + KYB AGX's.
don't get ebay coilover sleeves, they're worthless.
Old Feb 14, 2005 | 10:07 AM
9deuce9rr's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by maxvtec7500 &raquo;</TD></TR><TR><TD CLASS="quote">Good call, don't ever skimp on it because you will have the shittiest ride ever. Especially if you use coilover sleeves on stock struts, BAD IDEA! Save up for some eibach sportlines and KYB AGX's or something, just don't go cheap. Good luck </TD></TR></TABLE>
i ran coilovers on stock struts.. .BAAAAAAAAAD idea... saved up for sum AGXs and its probably one of the best mods i've done
Old Feb 14, 2005 | 01:36 PM
1995H23Lude's Avatar
Ground Control Coilovers are around 285...and then get KYG ABX's..pretty good set up that isnt to expensive but pretty good quality
Old Feb 14, 2005 | 01:48 PM
SiB16A's Avatar
Default Re: lowering methods. (1995H23Lude)
KYG ABX's are only recommended for a 1.5 drop anything after that good luck. spend 90 more bucks and get tokico illumina's or 200 more and get koni yellow's
Old Feb 14, 2005 | 03:46 PM
eMpAtHy's Avatar
i think if you went to the suspension forum they would be able to help you out a lot more.
Old Feb 14, 2005 | 04:02 PM
TxTuner
Guest
Posts: n/a
Default Re: lowering methods. (eMpAtHy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BS 22 &raquo;</TD></TR><TR><TD CLASS="quote">
same with ground control and skunk2. i think they only go for 200 im pretty sure.</TD></TR></TABLE>
You're talking about sleeved springs and they're crap. Bouncy ride and no :brain fart: control over bottoming out. Go with some nice sport springs. should give you about an 1.7" drop all around and you can pick em' up on ebay for around $150
Old Feb 14, 2005 | 06:13 PM
chrisgags13's Avatar
Default Re: lowering methods. (TxTuner)
or just get some skunk 2 coilovers with some tannabe shocks. its a good setup and is probably the least expensive out there for what you get.
Old Feb 14, 2005 | 07:30 PM
limpmode's Avatar
Default Re: lowering methods. (chrisgags13)
for a modest drop, try eibach prokit. you could prob run stock shocks if you don't hit too many rough roads, but aftermarket would be a good investment. it's about 1 1/4 in drop. they are not expensive either.
Old Feb 14, 2005 | 07:49 PM
bad-monkey's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TxTuner &raquo;</TD></TR><TR><TD CLASS="quote">You're talking about sleeved springs and they're crap. Bouncy ride and no :brain fart: control over bottoming out. Go with some nice sport springs. should give you about an 1.7" drop all around and you can pick em' up on ebay for around $150</TD></TR></TABLE>
not sure how sleeved springs wouldn't give you control over bottoming out if you could adjust the ride height to avoid it.
i agree that ebay sleeves are worthless, but i'll recommend ground control all day, every day.
Old Feb 15, 2005 | 05:21 PM
05member y0's Avatar
Cheap springs can blow your stock struts.... get some decent springs and definately upgrade your struts
Old Feb 15, 2005 | 06:01 PM
bby6's Avatar
I <3 Rotas
Default Re: (05member y0)
i run h&r race springs on stock struts and the ride is still good. the drop is 2" too. that's just my opinion though
Old Feb 15, 2005 | 09:25 PM
92LudeSI's Avatar
not to jack the thread but I have Ground controls right now on AGXs and im thinking about getting some h&r race or eibach pro. I want to have a moderate drop but a better ride. Can someone post up some pics of their cars on these setups.
Old Feb 16, 2005 | 08:50 AM
Kronn 98SH's Avatar
one of the best deals i've found
http://www.coximport.com/store/KE029
Old Feb 16, 2005 | 09:03 AM
bad-monkey's Avatar
Default Re: (92LudeSI)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92LudeSI &raquo;</TD></TR><TR><TD CLASS="quote">not to jack the thread but I have Ground controls right now on AGXs and im thinking about getting some h&r race or eibach pro. I want to have a moderate drop but a better ride. Can someone post up some pics of their cars on these setups. </TD></TR></TABLE>
just buy replacement ERS springs with softer spring rates. put the rear springs on the front and buy a pair of 200#/in springs for the rear.
also, how low are you? if you're too low there isn't enough shock travel and the ride's gonna suck.
gvon_accord
Nov 20, 2017 09:54 AM
MattZ28
Suspension & Brakes
Jun 26, 2008 12:59 PM
4doorek96
17
Jun 3, 2008 12:57 PM
iprobe
Honda Civic (2001 - 2005)
Jun 23, 2007 01:39 AM
Jaydeep
Jun 24, 2004 07:57 PM
