steering problem
Old Feb 15, 2005 | 02:47 PM
vtec_crazy's Avatar
Default steering problem
ok ive just gotten my car engine replaced and suspentions changed (put back to stock hight).. and also taken my car to get wheel alignment done 4 times and at 4 different places due to my car steering to left and right...
ok when drivingit just turns to the left like physically the steering wheel turns to the left a bit and the car moves to the left and sometime the car moves to the right mattering on the road...
why is that and how can that be fixed
thanks
Old Feb 15, 2005 | 03:26 PM
vtec_crazy's Avatar
Default Re: steering problem (vtec_crazy)
comon on no one knows anything
Old Feb 15, 2005 | 04:42 PM
The Phil's Avatar
why the hell would you replace your "car engine"? Your "suspentions" aren't the reason why the car moves to the right sometimes either. Think about it. The wheels are connected to the steering wheel. When you turn the steering wheel to the left, the wheels turn to the left, right? And since they're connected, if the road curves to the right, the steering wheel turns to the right, and the car moves to the right. That's why. You can't fix it because it's not a problem.
Old Feb 15, 2005 | 04:47 PM
vtec_crazy's Avatar
Default Re: steering problem (xthephilx)
first me telling you i changed my engine and springs and suspentions is just a a bit of info of what my cars had done to it.
and when not turning (GOING STRIGHT) my car goes to the left and sometimes to the rights.
i know this is a problem because i didnt have it before and other cars dont do that.
Old Feb 15, 2005 | 04:52 PM
The Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_crazy &raquo;</TD></TR><TR><TD CLASS="quote">and when not turning (GOING STRIGHT) my car goes to the left and sometimes to the rights.
i know this is a problem because i didnt have it before and other cars dont do that.</TD></TR></TABLE>
um no...thats because the road isn't perfectly flat. Sorry. It's not a problem.
Old Feb 15, 2005 | 05:06 PM
lenn's Avatar
its also dependant on the kind of tires you have... some tires are more succeptable to wandering. If you've gotten a bunch of allignments already, i'd say its the tires.... how much tread do you have left? My lude was driving strange just as I was running out of tread, new tires fixed the problem....
Old Feb 15, 2005 | 05:18 PM
jnet's Avatar
Sounds like torque steer.
Old Feb 15, 2005 | 05:26 PM
vtec_crazy's Avatar
Default Re: steering problem (jnet)
what do u mean more info on that.
is that somthing that can be fixed
tahnks
Old Feb 15, 2005 | 05:35 PM
jnet's Avatar
its a pretty common issue with FWD cars a lot of hondas have it because the drive axles are not the same length, but it is mostly prevalent on some modded cars with more torque. I have it, but i only notice it if i go over a bump or hole usually. i think replacing some of those things mentioned above can help it.
Old Feb 15, 2005 | 07:16 PM
93_EH2's Avatar
maybe its the tie-rod ends... i have the same problem
does it jerk from right to left or anything like that?
just go under and check the outter tie-rod end to see if the bushings are shot, if not then its probably the inner tie-rod bushings or the tie-rod is bent
Old Feb 15, 2005 | 07:50 PM
vtec_crazy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">
no fuckwad, you're the idiot. Even with brand new tires on my car, going over a large enough bump will make the steering wheel turn and...drumroll...make the car move.
And if it IS torque steer, which i doubt since he seems to be talking about going over bumps and the car moving (surprise surprise...), get a LSD. If you even know what that is.</TD></TR></TABLE>
ok ok IDOIt. its not when i hit a bump its when driving normal **** face... you think you know it by straigh away saying its not a fault well ******** it is....
First of all if you dont like what im posting then dont read it and reply.
i asked a question here to be helped not anything else .so go back to your ******* meeting.
lsd well sorry dic head i aint as rich as your fat head to go buying things becaus you said it.
Old Feb 15, 2005 | 07:51 PM
vtec_crazy's Avatar
Default Re: steering problem (x_blindsk8er_x)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by x_blindsk8er_x &raquo;</TD></TR><TR><TD CLASS="quote">maybe its the tie-rod ends... i have the same problem
just go under and check the outter tie-rod end to see if the bushings are shot, if not then its probably the inner tie-rod bushings or the tie-rod is bent</TD></TR></TABLE>
sorry everyone else this **** faces pissing me off
ok ok _blindsk8er_x ill give that a try thanks anyway
Old Feb 15, 2005 | 07:53 PM
The Phil's Avatar
Go sober up, get a dictionary and a typing tutor, then people might be able to help you.
Old Feb 15, 2005 | 08:57 PM
vtec_crazy's Avatar
man your a kid get a life
Old Feb 16, 2005 | 11:46 AM
The Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_crazy &raquo;</TD></TR><TR><TD CLASS="quote">man your a kid get a life</TD></TR></TABLE>
At least I'll have my high school degree when i'm your age.
Old Feb 16, 2005 | 12:17 PM
vtec_crazy's Avatar
**** your a dope i got degree(network/repair engineering) and i work for a highly integrated company called SERICE SOLUTIONS the founder of IBM..
while your at it dont act tough cuz a little pub hair came out on your face.
Old Feb 16, 2005 | 12:28 PM
The Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_crazy &raquo;</TD></TR><TR><TD CLASS="quote">**** your a dope i got degree(network/repair engineering) and i work for a highly integrated company called SERICE SOLUTIONS the founder of IBM..
Lets not turn this into a pissing contest...as of writing this I'm sitting in my office at NIST, pulling in about $35k. I'm 17. You work at an "integrated company" (what the hell is that?) that apparently doesn't know how to spell "service". Besides, I can't seem to find any company called SERICE SOLUTIONS. Maybe you're talking about this: http://www.can.ibm.com/services/selfservice, in which case your job is what? I didn't think so.
Old Feb 16, 2005 | 01:14 PM
vtec_crazy's Avatar
hahah sitting in an office looking up prelude web sites really shows everyone how much they need you. how much your daddy pay them to have you sit in the corner
YES my company called is called serice solutions. im from Australia you idiot.
and like a said a major source of IBM..
before i come down there and break your 4 eyed glasses on your head... GET A LIFE. i ain't gona waste my time on a pieces of **** like YOU.
Old Feb 16, 2005 | 01:21 PM
The Phil's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_crazy &raquo;</TD></TR><TR><TD CLASS="quote">hahah sitting in an office looking up prelude web sites really shows everyone how much they need you. <U>h</U>ow much your daddy pay them to have you sit in the corner<U>?</U>
YES my company called is called ser<U>v</U>ice solutions. <U>I'</U>m from Australia<U>,</U> you idiot.
<U>A</U>nd like <U>a</U> said a major source of IBM..<U>.</U>
<U>b</U>efore <U>i</U> come down there and break your 4 eyed glasses on your head... GET A LIFE. <U>i</U> <U>ain't</U> <U>gona</U> waste my time on a pieces of **** like YOU.
Actually, my dad died long before I got my job, so he didn't pay for it. I work in a roughly 40x60ft office, and I can sit wherever the hell I want. If you like, I can take a picture to show you. While I'm at it, would you like to see a pay slip? I doubt you have ever seen one with more than $25 on it in your life.
YOUR company? So now you're saying that at 21 you own a company? Maybe, being the owner of your "company", you could get around to spelling the name of your company right. And nice with all the e-thuggery...you know i'm really scared by that.
Old Feb 16, 2005 | 01:51 PM
PrecisionH23a's Avatar
Grow up.
-Locked and docked.
hcaulfield57
Suspension & Brakes
47
Oct 8, 2018 08:16 PM
teg_dc2
Mar 13, 2009 12:35 PM
Essence of Chicken
Nov 13, 2003 09:21 PM
