lights after acceleration
Old Feb 15, 2005 | 09:36 AM
Alikat's Avatar
Default lights after acceleration
I was driving down the hwy the other night and hit it to pass some slow people. When I got around them, I noticed that my check engine light had popped on, and then a few seconds later, my ATTS light popped on too. The car is running fine, but this isn't the first time this has happened to me. Anyone know what's up?
Old Feb 15, 2005 | 09:38 AM
Hawkze_2.3's Avatar
Default Re: lights after acceleration (Alikat)
Could be a million different things. You should check to see if you're throwing any codes....
Old Feb 15, 2005 | 09:39 AM
Alikat's Avatar
Default Re: lights after acceleration (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Could be a million different things. You should check to see if you're throwing any codes....</TD></TR></TABLE>
Can't check codes until this weekend, but that's definately the plan
Old Feb 15, 2005 | 09:49 AM
The Phil's Avatar
does it keep happening? does it go away if you reset your ECU?
Old Feb 15, 2005 | 12:12 PM
Alikat's Avatar
Default Re: lights after acceleration (xthephilx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">does it keep happening? does it go away if you reset your ECU?</TD></TR></TABLE>
This is the second time it has happened, my boyfriend has an OBDII scanner tool and we just erase the codes and the lights go away. It didn't happen immediately after we erased the codes the first time, but obvioulsy it does keep happening. haven't tried to reset the ECU.
Also, I have a vtec controller.....could there be something there that would be causing the lights to pop on?
Old Feb 15, 2005 | 12:18 PM
The Phil's Avatar
just a VTEC controller? or a VAFC or something like that? check your wiring on it...if its not completely covered in electrical tape or whatever you like to use to cover wiring then it could be shorting out and throwing codes. What code are you getting?
Old Feb 15, 2005 | 02:26 PM
Alikat's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">just a VTEC controller? or a VAFC or something like that? check your wiring on it...if its not completely covered in electrical tape or whatever you like to use to cover wiring then it could be shorting out and throwing codes. What code are you getting?</TD></TR></TABLE>
It's the Fields VTEC controller and I don't remember what codes we got the first time this happened. I'll let ya know on Friday what code it is.
Old Feb 19, 2005 | 12:03 PM
Alikat's Avatar
I'm getting the code 1259 for the lights. know what that is or direct me to where I can find it?
Old Feb 19, 2005 | 01:07 PM
mgags7's Avatar
its online just search for it, that does sound familiar though....
Old Feb 19, 2005 | 01:17 PM
britishlude's Avatar
This link to a site with list of codes might help, also below another list of codes found.
http://www.hondaprelude.to/art....html
1 Oxygen Sensor "A" (Primary) defective circuit or unplugged / defective sensor
2 Oxygen Sensor "B" defective circuit or unplugged / defective sensor
3 MAP Sensor (Manifold Absolute Pressure) defective circuit or unplugged / defective sensor
4 CKP Sensor (Crankshaft Position Sensor) defective circuit or unplugged / defective sensor
5 MAP Sensor (Manifold Absolute Pressure) mechanical problem / disconnected piping
6 ECT Sensor (Engine Coolant Temperature) defective circuit or unplugged / defective sensor
7 TP Sensor (Throttle Position) defective circuit or unplugged / defective sensor
8 TDC Sensor (Top Dead Center) defective circuit or unplugged / defective sensor
9 CYP Sensor (Cylinder) defective circuit or unplugged / defective sensor
10 IAT Sensor (Intake Air Temperature) defective circuit or unplugged / defective sensor
12 EGR Lift Sensor (Exhaust Gas Recirculation) defective circuit or unplugged / defective sensor
13 BARO Sensor (Atmospheric Pressure) defective circuit or unplugged / defective sensor
14 Ignition Output Signal missing or defective ignition output signal
16 Fuel Injector System defective circuit or unplugged / defective fuel injector
17 VSS (Vehicle Speed Sensor) defective circuit or unplugged / defective sensor
19 Automatic Transmission Lock Up Control Solenoid Valve defective circuit or unplugged / defective solenoid valve
20 Electrical Load Detector defective circuit or unplugged / defective sensor
21 VTEC Solenoid Valve defective circuit or unplugged / defective solenoid valve
22 VTEC Oil Pressure Switch defective circuit or unplugged / defective oil pressure switch
23 KS (Knock Sensor) defective circuit or unplugged / defective sensor
30 Automatic Transmission Signal: "A" / SEAF / SEFA / TMA or TMB defective circuit or unplugged / defective sensor
31 Automatic Transmission Signal "B" defective circuit or unplugged / defective sensor
41 Primary Oxygen Sensor - Heater circuit malfunction
43 Fuel Supply System defective or malfunctioning fuel supply system
45 System Too Lean or Too Rich malfunction in the fuel monitoring systems
48 LAF Sensor (Lean Air Fuel) defective circuit or unplugged / defective sensor
54 CKF Sensor (Crankshaft Speed Fluctuation) defective circuit or unplugged / defective sensor
61 Oxygen Sensor, Heated - Sensor 1 (Primary) high voltage, low voltage, or slow response
63 Oxygen Sensor, Heated - Sensor 2 (Secondary) high voltage, low voltage, or slow response
65 Oxygen Sensor Heater (Secondary) malfunctioning or defective oxygen sensor heater
67 Catalyst system Efficiency Below Threshold malfunctioning or defective catalyst system
70 Automatic Transmission malfunction with the automatic transmission controls
71 Cylinder 1 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
72 Cylinder 2 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
73 Cylinder 3 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
74 Cylinder 4 Misfire or a Random Misfire a condition is present that is creating a cylinder misfire
80 Exhaust Gas Recirculation insufficient flow detected
86 ECT Sensor (Engine Coolant Temperature) circuit range / performance problem
90 Evaporative Emission Control System leak detected in the fuel tank area
91 Fuel Tank Pressure Sensor low input
92 Evaporative Emission Control System insufficient purge flow
Old Feb 19, 2005 | 07:55 PM
Alikat's Avatar
Default Re: lights after acceleration (britishlude)
yeah, i'm actually on that board but that didn't help much. Thanks though. When searching on the internet I found that the code was "immobilizer to PCM signal error".....anyone know what that means???
Old Feb 20, 2005 | 07:27 AM
PrettyLude's Avatar
llights code, never heard of that before
Mikes2000civicsi
10
Sep 30, 2007 07:03 PM
ITRiWISH
11
Aug 27, 2007 05:24 PM
Quade
Nov 24, 2005 12:15 PM
osuperjohno
Jul 28, 2005 08:17 AM
B_CRUZ!
12
Aug 10, 2003 04:05 PM
