Prelude problem Pls Help
Old Feb 16, 2005 | 07:19 AM
Silencer RPMs's Avatar
Default Prelude problem Pls Help
ok i recently bought a h23 92096 prelude. i let my cousin change my oil, well he didn't put enough in and 2 weeks later I started hearing a clicking noise. So I got the exhaust camshaft and timing belt changed. Now I still hear the clicking, its reving from 1-2,000 rpms, and i think the valves are messed up. any ideas? suggestions?
Old Feb 16, 2005 | 07:21 AM
RA062424's Avatar
Default Re: Prelude problem Pls Help (Silencer RPMs)
wow, so you were driving with not enough oil?
Old Feb 16, 2005 | 07:31 AM
Default Re: Prelude problem Pls Help (rseaburgh)
yep 2 weeks with no engine oil. not only that i was racing the car every opprotunity i got against anyone that i could. lmfao. lucky it didn't mess up earlier
Old Feb 16, 2005 | 09:08 AM
bad-monkey's Avatar
with no engine oil or with low engine oil? did the cel ever come on?
the tick sounds like your valves. the timing belt/exhaust cam change was a waste of money, too. get your valves readjusted.
if you ran the car for 2 weeks with NO oil, the engine would have seized. low oil it might have been ok, however, you could have fubared the engine. get the valves readjusted and see what happens. also do a compression check/leakdown test.
Old Feb 16, 2005 | 11:48 AM
The Phil's Avatar
with no oil I would be surprised if it had started. Your valves are probably done but
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bad-monkey &raquo;</TD></TR><TR><TD CLASS="quote">get the valves readjusted and see what happens. also do a compression check/leakdown test. </TD></TR></TABLE>
do that
Old Feb 16, 2005 | 12:13 PM
Shakes's Avatar
space cadet
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silencer RPMs &raquo;</TD></TR><TR><TD CLASS="quote">yep 2 weeks with no engine oil. not only that i was racing the car every opportunity i got against anyone that i could. lmfao. lucky it didn't mess up earlier</TD></TR></TABLE>
so wait a minute. let me get this straight here.
1 - you didn't check it. that means you don't care enough to make sure it was done right.
2 - you were racing (most likely street racing so you should be shot) and didn't care enough to check your fluids and im sure anything else.
3 - now you come begging for help so that you can repeat both #1 and #2, all the while still not caring what happens to your engine as long as you can race someone.
here is the solution.
take your car to a salvage yard. sell it to them for scrap metal then take that money and buy a gun and one bullet. yes just one. you can barney fife it for a while. go get some dinner and then shoot yourself in the ******* head. you don't deserve your car or the privilege to drive.
good bye.
Old Feb 16, 2005 | 05:46 PM
RA062424's Avatar
Default Re: Prelude problem Pls Help (Shakes)
I'd just kick my cousin in the nutz really hard.
Old Feb 16, 2005 | 08:57 PM
eMpAtHy's Avatar
ur cousin is an idiot.
no oil=nothing gets lubed..metal on metal is not an engines best friend.
imagine sex. if people did not produce fluids down there, sex would be painful..not fun.
go ********** with sandpaper.
hopefully you get my point.
Old Feb 16, 2005 | 09:10 PM
The Phil's Avatar
Default Re: Prelude problem Pls Help (eMpAtHy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by eMpAtHy &raquo;</TD></TR><TR><TD CLASS="quote">go ********** with sandpaper.</TD></TR></TABLE>
hahahha
Old Feb 16, 2005 | 09:20 PM
DcWest's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Shakes &raquo;</TD></TR><TR><TD CLASS="quote">
good bye.</TD></TR></TABLE>
whoa, take it easy fellow luder.
Old Feb 16, 2005 | 10:06 PM
SKDRCR's Avatar
Default Re: Prelude problem Pls Help (DcWest)
I would get the valves adjusted and go from there.
Old Feb 16, 2005 | 10:10 PM
bby6's Avatar
I <3 Rotas
no offense, but seriously, people like you make honda-tech look like a place full of ********. atleast try and be helpful. damn and sorry, i'm not really helping either, haha.
Old Feb 16, 2005 | 10:19 PM
SKDRCR's Avatar
Default Re: Prelude problem Pls Help (girLuder)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by girLuder &raquo;</TD></TR><TR><TD CLASS="quote">no offense, but seriously, people like you make honda-tech look like a place full of ********. atleast try and be helpful. damn and sorry, i'm not really helping either, haha.</TD></TR></TABLE>
Doug's not an *******, he's a pretty good guy.
But you gotta understand where he's coming from. vvvvvvvvvvv
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Silencer RPMs &raquo;</TD></TR><TR><TD CLASS="quote">yep 2 weeks with no engine oil. not only that i was racing the car every opprotunity i got against anyone that i could. lmfao. lucky it didn't mess up earlier</TD></TR></TABLE>
This sounds like rice at it's finest
The guys lucky that he hasn't spun a bearing.
Anytime you hear clicking, check your oil with the quickness
Old Feb 16, 2005 | 10:24 PM
PrecisionH23a's Avatar
Default Re: Prelude problem Pls Help (SKDRCR)
n00bs just aren't getting the proper flaming like back in the day. leave it to doug to re-invent the flame. doug... a real flamer.
On a tech note, you better pray that you only hear your valves ticking. Your bearings are probably toast and knocking though. Usually when you increase the rpm's and you hear the sound getting louder that's usually coming from the area of the crank. I would drop the oil pan if I were you and check for shavings/chunks of bearings. Your cylinder walls are probably scored nicely as well. Most likely you'll need a new engine soon... if not you are one lucky SOB.
Kick your cousin in t3h nuts also when you have a chance.
giovannie23
12
May 8, 2014 08:57 PM
xpoint
Nov 9, 2012 03:31 PM
JDM B20Lude
Aug 6, 2009 02:12 PM
MathewAshley
Sep 29, 2004 01:07 PM
SkoundrelUSA
Aug 28, 2004 11:25 AM
