which camber kit?
Old Mar 15, 2005 | 12:57 PM
fafsa's Avatar
Default which camber kit?
whats the cheapest/best camber kit everyone is running?
Old Mar 15, 2005 | 01:06 PM
Brnymac's Avatar
Default Re: which camber kit? (fafsa)
i dont think its the cheapest but i have skunk2 front and that ran me like 200 and they fit perfect.
Old Mar 15, 2005 | 01:11 PM
jc836's Avatar
This comes up a lot. The cost is not the issue-the quality is. You cannot simply buy a kit-you MUST have the alignment printout in order to select the correct pieces for your car. Both SPC and Ingalls make some really good parts. If you look at my AD you will see what we used for our specific drop on the car.
NO 2 cars are alike. However, the general rule for Camber correction is - for each 1" of drop your Camber will go negative by ~0.84 degrees from wherever it was originally. ANother thing-the SPC front balljoint kits (67135 for example) allow a small amount of Caster correction during the install. Get the Caster as close to equal on both sides as possible. For additional info on kits go to both the SPC and Ingalls sites. They have great info on the subject.
Old Mar 15, 2005 | 03:57 PM
Sourpatch's Avatar
Default Re: which camber kit? (jc836)
I got the ingalls a while back after I put neuspeed springs on, seemed to correct it pretty good. price wasn't too bad either.
Old Mar 15, 2005 | 08:15 PM
OaksRacing's Avatar
Default Re: which camber kit? (Sourpatch)
We are running SPC camber kits this year with Skunk2 springs, Koni Shocks
Alignment is a must.
Old Apr 19, 2005 | 06:30 PM
Prelude-TeCh's Avatar
Default Re: which camber kit? (OaksRacing)
Im looking to buy a camber kit and i just dont know which one in specific. can u guys help.
Fo-Do Fanatic
20
Feb 10, 2011 01:34 PM
BJA86
11
Sep 2, 2007 01:00 PM
ef-b16sedan
19
Mar 29, 2007 06:12 AM
ActiveAero
May 23, 2002 12:14 AM
