climate control cable problems
Old Mar 11, 2005 | 10:02 AM
yOnKiNaToR's Avatar
Default climate control cable problems
heres' the deal: the switch on the heater under the dash seems to be really hard to turn from hot to cold. this is causing the cable that is connected to be stripped so now i need another cable. but the plastic stop piece has broken off on one end b/c of the stress the cable put on it.
is there a reason the heater is flipping from hot to cold so hard? any way to fix it?
btw: i've lubed up everything that moves down there and it's still tough.
Old Mar 11, 2005 | 11:15 AM
DarkBB4's Avatar
Default Re: climate control cable problems (yOnKiNaToR)
gointo the engine compartment and find the heater valve
take of fhte metal clip and just swing it open and closed a few teimes maye alittle lubricant
also, Sometimes the CLIPS holding hte metal wire in the interior get crusty and wont allow the line to move INSIDE... so take those off
integra15's Avatar
Yes, you need to lube the cable beyond the firewall that is in the engine compartment. It should be low in the middle of the firewall. Spray the cable and control valve with wd40 and it should be like new.
Old Mar 11, 2005 | 12:27 PM
yOnKiNaToR's Avatar
Default Re: climate control cable problems (integra15)
sry but i did that guys. i sprayed the hell out of that whole assembly with silicone grease.
maybe it's just naturally that hard to pull. i have to put quite a bit of force to turn it by hand so i can't imagine that a little cable could pull with such force.
Old Mar 11, 2005 | 12:49 PM
shl76's Avatar
i just replaced the cable itself and mine works good as new now.
Old Mar 11, 2005 | 04:12 PM
five-0's Avatar
Default Re: climate control cable problems (shl76)
Cable inop, R&R to test OK.
nothing_shocking
Jan 21, 2010 12:48 AM
allmotorek8
Feb 21, 2006 02:44 PM
turboman
Nov 16, 2005 09:26 PM
stevescivic
Aug 11, 2005 06:28 PM
itsJDMyo
Oct 30, 2003 05:39 PM
