Engine break in? Tuning?
Old Mar 18, 2005 | 07:53 AM
Pikachu's Avatar
Default Engine break in? Tuning?
Ok, my motor is currently being built. It consists of a GE sleeved open deck H22(stock bore), 9 to 1 compression pistons and pauter rods. Everything else is stock. This is going to be dropped into my 92 CX hatch. I spoke to a tuner about breaking it in on a dyno and he told me that I didn't need to tow it to him. He told me since the only thing that's different on this motor is the compression, the stock P13 should run it fine. Now my question is, Is it safe to drive on the honda ecu to the tuner(1.5hrs away)? Could I break it in with a stock ecu on? I'm taking it to my tuner so he can tune my AEM EMS. This is completely NA. Tried the tuning forum but no one seems to know. Thanks in advance guys.
Old Mar 18, 2005 | 08:00 AM
94vtecmn's Avatar
Default Re: Engine break in? Tuning? (Pikachu)
Just don't be revving it up into VTEC, drive it really nice, and don't hold a steady speed, try to vary your speed, slowing and speeding up to let the motor rev up and down through the 2500-4500 rpms.
PrecisionH23a's Avatar
Run the stock computer with the stock injectors. Don't take it above 3-3500rpms and you'll be fine.
If this is a daily driven motor I would personally put at least 500-1000 miles on it before tuning. That's just me though...
Old Mar 18, 2005 | 08:02 AM
Pikachu's Avatar
Could I drive it like 1000 miles on stock ecu, then install turbo and then tune it? This is not a daily driven motor. It is my weekend track car.
Old Mar 18, 2005 | 08:04 AM
Default Re: (Pikachu)
I break cars in like they are used. If it's a drag car... go ahead and heat cycle the engine for 30 min and tune it. The rings will seal better after time goes by... It will be fine to drive on the stock ecu as long as you have stock injectors and fuel pressure.
Old Mar 18, 2005 | 11:50 AM
Pikachu's Avatar
What should the compression numbers be across the cylinders after 1k miles? Should I change my oil at this point as well?
Old Mar 18, 2005 | 11:54 AM
Eddiebx's Avatar
bring it to my house, i'll break her nicely for you, oh i meant break in
Old Mar 18, 2005 | 03:13 PM
2.2SICKLUDE's Avatar
Default Re: Engine break in? Tuning? (PrecisionH23a)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PrecisionH23a &raquo;</TD></TR><TR><TD CLASS="quote">Run the stock computer with the stock injectors. Don't take it above 3-3500rpms and you'll be fine.
If this is a daily driven motor I would personally put at least 500-1000 miles on it before tuning. That's just me though...</TD></TR></TABLE>
I'd break it in with at least 1000 miles
G2IntegraGS
Engine Management and Tuning
May 2, 2009 05:51 PM
Mr.Hankey
Dec 6, 2006 04:44 PM
.adam.
Jul 8, 2006 01:06 PM
Pikachu
Mar 18, 2005 11:16 PM
