o2 sensor
Old Mar 14, 2005 | 10:40 AM
Monkey Fing a Coconut's Avatar
Default o2 sensor
other than checking by part numbers which are different, are 4th gen accord and 4th gen h22a o2 sensors the same in terms of signal they provide??? would using a 4th gen accord o2 sensor on the h22a be why it is running rich(i know it normally runs rich but its running richer than the normal rich)???
thanks
Old Mar 14, 2005 | 11:07 AM
kulrevon's Avatar
Default Re: o2 sensor (twistedbydezign)
I was almost positive that most 4 wire honda/ acura o2 sensors are the same. the only difference is the wire length. I have a friend that works at honda an thinks the same thing. No idea why there is such a difference in price.
so you should not ahave a problem running an accord o2 sensor.
I have one question why do you think you are running rich? (flames/ airfuel meter/ smell) just wondering.
Old Mar 14, 2005 | 12:18 PM
raylude's Avatar
From: united states of mexico and yes ladies i am, available
Default Re: o2 sensor (kulrevon)
thats what i was wondering cuz on the 5th gens there are 2 different o2 sensors depending on year and tranny. i ask on a different thread but a mod locked it
Old Mar 14, 2005 | 09:27 PM
Default Re: o2 sensor (raylude)
i am failing the HC part of smog, my o2 % is 0% so i am using all of the oxygen, but i am leaving unburnt fuel, even with lower octane(89) so it is definately running richer than it should be, all sensors are in place(iat, etc..) and i am not throwing any codes, so the only thing that could be making me run so rich is o2 i think, unless one of the IM runners is blocked and no air is getting through which i doubt....
Old Mar 15, 2005 | 08:06 AM
ttt
Old Mar 15, 2005 | 09:29 AM
kulrevon's Avatar
My butterflies werent working for a while I used to throw nice flames out the exhaust between 1st and 2nd and 3rd shifting. I didnt have a cat in. but I did have a resonator and muffler. check to see if your butterflies move if you rev it up from under your hood.
not saying its your answer I just know that my car liked running rich and throw flames when my butterflies werent working.
Old Mar 15, 2005 | 10:06 AM
well right now i dont really care about it running rich past 3000rpms, im trying to get smog taken care of which is only 15/25mph and <2000rpms...so butterflies wouldnt matter at that low of speed
Old Mar 16, 2005 | 04:23 AM
ttt, anyone whether the signal from 4th gen accord and 4th gen h22a o2 sensors are the same or different???
J-Civic SIR
Mar 22, 2012 09:48 PM
stock95coupe
Oct 16, 2011 09:16 PM
Marcpb443
Jun 15, 2009 03:58 PM
eswaroop
Apr 5, 2004 04:19 PM
radiac
Jul 5, 2001 08:45 PM
