window motor install?
Old Mar 11, 2005 | 02:34 PM
1998teg's Avatar
Default window motor install?
my passenger window all of a sudden stopped working. there was no whining noise or anything prior to it stopping so i tested the electrical. the motor and switch were getting power so i guess it is the motor. im planning on installing one myself but dont know how hard the job is and wether or not it can be done with basic tools. if anyone knows fill me in.
Old Mar 11, 2005 | 03:19 PM
SKDRCR's Avatar
Default Re: window motor install? (1998teg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1998teg &raquo;</TD></TR><TR><TD CLASS="quote">my passenger window all of a sudden stopped working. there was no whining noise or anything prior to it stopping so i tested the electrical. the motor and switch were getting power so i guess it is the motor. im planning on installing one myself but dont know how hard the job is and wether or not it can be done with basic tools. if anyone knows fill me in.</TD></TR></TABLE>
Yes, it's easy and can be done with simple tools.
Are you sure that the switch on the drivers side that controls both sides is on?
Old Mar 12, 2005 | 01:03 PM
1998teg's Avatar
Default Re: window motor install? (SKDRCR)
the drivers side window works so i figure its working for the passenger. plus i believe if the passenger is getting power than that means the drivers is working since the power for the passenger comes from the drivers side. (correct me if im wrong)
Old Mar 13, 2005 | 06:28 PM
PrettyLude's Avatar
pretty easy job, make sure you line it up with the tracks when you put it back together
Old Mar 14, 2005 | 05:19 PM
1998teg's Avatar
Default Re: (PrettyLude)
do i have to take the actual glass out of the window to do this. also i was wondering if i need to put the plastic lining back on the door after im done.
Old Mar 14, 2005 | 08:48 PM
PrettyLude's Avatar
yes put the plastic lining back, that keeps some of the road noise out the car, and you will have to take the window out, becareful
Old Mar 15, 2005 | 06:58 AM
1998teg's Avatar
i read that you have to drill out the old motor from the door and rivet a new one in. im pretty sure i wont have a problem drilling the old one out but im not sure what is needed to rivet a new motor in the door. my choltons manual said to use a ball peen hammer to rivit it in but i have done rivets like that before in metal shop and they didnt hold to well. if yuo know of a better way let me know if not ill just have to get better at rivetting.
Old Mar 15, 2005 | 07:30 AM
PrettyLude's Avatar
the motor should be held on by 10mm bolts, not rivets, what year are you referring to?
Old Mar 15, 2005 | 02:56 PM
1998teg's Avatar
i have a 1998 ls. i didnt think the rivet thing made much sense myself but thats what my chiltons manual says.
also let me know if im goin to have to buy new plastic wire holders that connect to the door since i think im just going to have to break them off unless you know a way to pry them off without breaking them.
Old Mar 15, 2005 | 07:50 PM
PrettyLude's Avatar
if your talkin about the clips that hold the panel onto the door, just pry on them gently, it will not break, take time when you take things like this apart, you can break things real easily, just take your time, and make sure you look for all screws and bolts before you start pulling on stuff
leopauvin
Jul 23, 2011 12:00 PM
jds113
Aug 7, 2010 05:04 PM
da_ska
May 31, 2009 02:32 AM
