engine stalling on me when I'm in neutral
Old Mar 15, 2005 | 03:09 PM
95preludetemp's Avatar
Default engine stalling on me when I'm in neutral
Hi everybody,
I have a 95 SI that keep dying on me when I'm riding in neutral. It not giving any error code at all. Just the battery and oil light comes on when it die. It usually occur when I coming to a stop sign and I shift it to neutral. If anyone can point me toward fixing this problem, I would appreciate. The car has 166K miles. I recently changed the water pump, timing belt, all the drive belt and fuel pump. I'm at a lost right now. Could be possible be the MAP sensor?
TIA
Tony
Old Mar 15, 2005 | 03:14 PM
The Phil's Avatar
Default Re: engine stalling on me when I'm in neutral (95preludetemp)
Modlist? and have you done anything recently?
Old Mar 15, 2005 | 03:34 PM
Dougs96SI's Avatar
Is it stalling on you when you have the clutch pushed in and just rolling, or when the car is actually in neutral and the clutch is out, or both?
EDIT-- Typing owns me
Old Mar 15, 2005 | 04:14 PM
dc5r2002's Avatar
Default Re: engine stalling on me when I'm in neutral (Dougs96SI)
mine does the same thing when i push in the clutch and come to a stop, it only happens sometimes though
Old Mar 15, 2005 | 04:20 PM
Default Re: engine stalling on me when I'm in neutral (Pulp Fiction)
It's stalling when I rolling in neutral. The clutch is out. No mode on the car at all except a cold air intake.
Old Apr 15, 2005 | 12:40 PM
dj626's Avatar
I'm having the exact same problem.
Old Apr 15, 2005 | 12:58 PM
ludeDVR's Avatar
I used to have that problem until i replaced it with a jdm h22a lol
Old Apr 15, 2005 | 01:37 PM
IHateJDM's Avatar
Default Re: (ludeDVR)
i have that problem from time to time on a jdm h22. I can't crank it right away either, I have to give it at least 10 secs first. otherwise a few cylinders will fire and it'll die again.
Old Apr 15, 2005 | 01:52 PM
SearchBeforeUPost!'s Avatar
Default Re: (IHateJDM)
Check your plugs to see if they are fouled, also check the throttle body for carbon build-up.
Old Apr 15, 2005 | 07:26 PM
2gn9gencevg's Avatar
Try a compression test to see if your valves are bent.
Old Apr 15, 2005 | 07:45 PM
The Phil's Avatar
Default Re: engine stalling on me when I'm in neutral (2gn9gencevg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2gn9gencevg &raquo;</TD></TR><TR><TD CLASS="quote">Try a compression test to see if your valves are bent.</TD></TR></TABLE>
That would make his car stall only when the clutch is down?
Old Apr 16, 2005 | 06:32 AM
01 LudeDude's Avatar
Default Re: engine stalling on me when I'm in neutral (xthephilx)
Mine used to do that **** too, a few turns of the idle screw is all it took to fix.
Old Apr 17, 2005 | 02:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xthephilx &raquo;</TD></TR><TR><TD CLASS="quote">
That would make his car stall only when the clutch is down? </TD></TR></TABLE>
No, when I had bent valves my car would stall in nuetral weather the clutch was up or down.
Old Oct 18, 2023 | 08:24 PM
jdmbaby313's Avatar
I know this is a long shot considering the fact that it’s been years since this post but any chance on an update? Having the same exact issue. H22 swap ‘93 prelude. PLEASE HELP
category5 SI
Jun 26, 2008 09:17 PM
Re3irth
55
Dec 20, 2007 12:01 PM
nk2k2
Jul 22, 2006 10:14 AM
InfamousLude
Aug 3, 2005 04:53 PM
Key
Jun 28, 2002 02:26 PM
