Transmission Problems
Old Mar 15, 2005 | 05:21 PM
billcor's Avatar
Default Transmission Problems
I have a 94 Prelude, when I try to shift it grinds, but not all the time, if the car sits for a few days its good for several miles then I can't shift gears again. Someone told me that there is a switch or sensor that can go bad. Or do I need a new clutch or tranny?
Any help would be greatful.
Old Mar 15, 2005 | 05:35 PM
AndyD's Avatar
Default Re: Transmission Problems (billcor)
If you've never changed the clutch since you've owned the car, I am willing to bet the clutch needs to be replaced.
The first thing I would do is change the tranny fluid if you are not in the position to get the clutch replaced.
Old Mar 15, 2005 | 06:41 PM
steveobb4's Avatar
Default Re: Transmission Problems (AndyD)
Change your gear oil with honda manual transmission fluid. Also honda released a TSB (Tech Service Bulletin) on prelude and accord manual trannys for 5th gear upshift grinding and bent shift forks.
nmb16a
Transmission & Drivetrain
Jan 31, 2010 07:43 PM
arielb1
Dec 12, 2009 01:34 PM
gooberwolf
Apr 11, 2007 07:27 PM
VTECRaZeR
May 30, 2004 02:39 PM
PatrickGSR94
Apr 23, 2003 11:05 AM
