battery relocation
Old Mar 12, 2005 | 04:49 AM
vtec_lude's Avatar
Default battery relocation - wire length
Ok I've search through a few threads, but what i wanna know is how much wire do i need? i know i need 0/2 gauge wire but what length approximately will i need? I'm thinking about 4-5 metres will do?
Thanks
Old Mar 12, 2005 | 05:01 AM
somboa's Avatar
Default Re: battery relocation - wire length (vtec_lude)
Probably about 16-18 feet depending on where you want it mounted in the trunk. Just buy 20 to be safe.
Old Mar 12, 2005 | 05:05 AM
clemsoncb7's Avatar
Default Re: battery relocation - wire length (somboa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by somboa &raquo;</TD></TR><TR><TD CLASS="quote">Probably about 16-18 feet depending on where you want it mounted in the trunk. Just buy 20 to be safe. </TD></TR></TABLE>
Word, actually a good way to go is to buy jumper cables. They are less than half the price of buying the wire alone from a store and they are the same gauge and work just as well if not better. The entire amount of wire I needed ended up costing me about $15.00american dollars. GOod luck!
Old Mar 12, 2005 | 05:32 AM
digitalh3lix's Avatar
jumper cables.. really good idea.. where do u hide the wiring tho? thru firewall or under the car?
Old Mar 12, 2005 | 06:08 AM
Greyout's Avatar
Default Re: battery relocation - wire length (digitalh3lix)
Under the carpet... I was lazy and ran mine through the hole that was left over from the cruise control cable, but the rubber boot on the passenger size under the fuze box is also a good one.
Old Mar 12, 2005 | 06:52 AM
Sam1am26's Avatar
Default Re: battery relocation - wire length (Greyout)
I ran the cable through the fender and then through a hole in the firewall that pops out near the ecu and then ran it under the carpeting...
Old Mar 12, 2005 | 08:12 AM
vtec_lude's Avatar
thanks for all the replies.. i got myself about 19 feet of cables.. expensive in london but still better than buying those kits..
I've also heard of people using an 150amp fuse and also a power distributer.. are these both necessary??
Thanks again!
Old Mar 12, 2005 | 10:20 AM
clemsoncb7's Avatar
Default Re: (vtec_lude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by vtec_lude &raquo;</TD></TR><TR><TD CLASS="quote">thanks for all the replies.. i got myself about 19 feet of cables.. expensive in london but still better than buying those kits..
Thanks again!</TD></TR></TABLE>
Nope, you don't need either of those. You'll be fine just running your positives and ground. Good luck!!!
Old Mar 14, 2005 | 03:37 PM
vtec_lude's Avatar
ok so i got my wires and everything but i'm not sure how to hook it up..
I'm stuck on how to connect the starter and fuse box to the positive wire to the back..
I ran the wire under the carpet and through the firewall already..
Do i just separate the 2 wires ( one from the fuse and one from the starter) connect these together and then connect them with the positive wire? if so how do i go about doing this?
Thanks for the help!
Old Mar 15, 2005 | 02:27 PM
KSD81076's Avatar
Default Re: (maxvtec7500)
you defiantly need a fuse. 150amp is a good idea. The reason for the fuse is to protect your car and yourself in the case of an accident. If you get into a wreck you run the posability of pinching your power wire. When this happens the battery will see full ground allowing max current to flow. With nothing to stop it your battery, wire, and connectors will heat up causing a fire. Your fuse should be no more than 18in away from the battery.
Just my 2 cents.
Good luck.
Old Mar 15, 2005 | 04:56 PM
sup gurl's Avatar
Don't mean to hi-jack your thread but I would also like to do this, IM me on AIM if you can help me.
EG6 PSI
Dec 31, 2008 01:27 PM
SRd240sx
Audio / Security / Video
Aug 20, 2006 06:14 PM
rice r0cket
11
Jul 5, 2004 03:43 PM
MonkeyMagic
May 5, 2004 10:56 PM
