limiter and vtec problem .
Old Mar 12, 2005 | 04:10 PM
salman's Avatar
Default limiter and vtec problem .
hi all .
i have a prelude 96 its dohc and vtec i am having problem with rev limiter tht i come at 6200 rpm and vtec it dose not on till tht .
i mean when vtec dosent open the rev limiter comes to 6200 rpm . some times when vtec runs it come to 7500 . why is this happening i have rsm not plug vafc its pluged . wht should i do ,,
secondly i need to adjust TPS . for this i need setting ,,
thankx
salman
Old Mar 12, 2005 | 04:40 PM
A Blue Lude's Avatar
Default Re: limiter and vtec problem . (salman)
How's your oil level look?
Old Mar 12, 2005 | 07:17 PM
jdmlude_dude's Avatar
Default Re: limiter and vtec problem . (Featherfire)
i dont mean to sounds rude, but i didnt really understand what you were saying, well i did..but anyway! Yeah check the oil level first thing. If the oil is low and the oil pressure is down, then vtec may not engage. If that is fine, it could be wiring related, but 9 times out of 10 it would trip a code. The VTEC solenoid or pressure switch may be going bad.
Old Mar 13, 2005 | 09:27 AM
salman's Avatar
Default Re: limiter and vtec problem . (jdmlude_dude)
i am having problem with vtec it dose not work all the time some time it works and some time it dont .
well the oil level is ok . just changed the oil .
how to check for the vtec solenoid . pressure switch,
Old Mar 13, 2005 | 10:27 AM
SiRLudeVtec's Avatar
Did you properly warm the vehicle....? I don't think vtec will come on if the vehicle isn't at it's optimum temperature....
Old Mar 13, 2005 | 06:14 PM
PrettyLude's Avatar
the settings for the tps are .5 closed and 4.5 wot
Old Mar 13, 2005 | 10:44 PM
salman's Avatar
Default Re: (PrettyLude)
in my other car the TPS have 4 terminal it was some thing like tht ,.
1-2 =.5-10 kh
1-4 =35 - 55 ohms
i dont now how much ternimal are there in prelude ,
sorry but please tell me tht dose this WOT means .
the values are in kilo ohms or ohms .
Old Mar 13, 2005 | 10:46 PM
salman's Avatar
Default Re: (salman)
what dose WOT means ..??
Old Mar 14, 2005 | 12:43 AM
WOT means Wide Open Throttle - "Pedal to the floor"
HondacivDX
Feb 19, 2012 06:52 PM
Pleiadi79
Jun 12, 2008 08:22 AM
punkassazn
Oct 1, 2004 12:13 PM
speedunlimited
Sep 16, 2004 08:08 AM
zer0zer0 TypeR
Jun 6, 2002 04:53 AM
