Feedback from engine through speakers?
Old Mar 15, 2005 | 10:45 AM
ItalynStylion's Avatar
Default Feedback from engine through speakers?
I have some feedback coming through my speakers. I think its from the engine b/c its related to RPM, like reving the engine makes the noise faster. I have run my power wire to the amp on the oposite side of the car and the RCA cables are on the drivers side. The RCA's go from the sterio under the drivers feet carpet along the side of the car and to the trunk where the amp is for my componants. What can i do to fix this?
Is there like a magnetically shielded type of RCA wires i could get or something?
Old Mar 15, 2005 | 11:08 AM
Sticky Tires's Avatar
* B A N N E D *
Default Re: Feedback from engine through speakers? (ItalynStylion)
Ah the whining noise. I believe that has something to do with your alternator. All you need is a power cap, 1 farat.
Check your ground wires also. Make sure it's touching bare metal and not sitting on paint.
Old Mar 15, 2005 | 01:15 PM
Default Re: Feedback from engine through speakers? (Sticky Tires)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Sticky Tires &raquo;</TD></TR><TR><TD CLASS="quote">Ah the whining noise. I believe that has something to do with your alternator. All you need is a power cap, 1 farat.
Check your ground wires also. Make sure it's touching bare metal and not sitting on paint. </TD></TR></TABLE>
Yes, i have sanded off all the paint on my ground points. What do you mean i need a new cap, and what is a farat? Like distributor cap??
Old Mar 15, 2005 | 01:29 PM
Jagan'92's Avatar
Like a capacitor cap, in parallel with your power feeder to filter it. (and it's farad, not farat)
You may have some cables already running along the driver's side, another thing to try is running the rca cables under the carpet in the center of the car, under the console etc.
There are shielded cables you can get, and you can also buy line filters for the rca cables that sometimes work. There is also a filter capacitor available that attaches directly at the battery.
Old Mar 15, 2005 | 04:16 PM
Speedra500's Avatar
Default Re: Feedback from engine through speakers? (Jagan'92)
It is most likely a grounding problem, just as a test, try running a ground strap wire from your head unit to your amp
Old Mar 15, 2005 | 07:45 PM
PrettyLude's Avatar
long ground wires will also cause this too
Old Mar 15, 2005 | 07:54 PM
steme's Avatar
Ground loop isolator 15 dollars at wal-mart
Old Mar 15, 2005 | 08:00 PM
lude_behavior's Avatar
Default Re: (steme)
Ground Loop Isolator
This is my area of expertise as I do this for a living lol finally something I can contribute to. A ground loop isolator should fix this, a capacitor wouldn't solve this at all. A capacitor holds a completly different function.
Old Mar 15, 2005 | 09:36 PM
Default Re: (lude_behavior)
im tellin ya, my grounds are fine....i sanded the crap out of the spot they are grounded to. I stripped all the paint off and took off a little metal too.
abusedvtec
May 4, 2008 09:56 AM
PooM
Audio / Security / Video
17
Jul 21, 2006 08:05 AM
Jacen
22
Jan 12, 2006 09:49 AM
JDMlyfestyle
12
Dec 10, 2004 04:24 PM
i want a civic
10
Jun 10, 2002 08:52 PM
