JDM F22B dohc NON VTEC block / H22 dohc VTEC head???
Old 07-17-2012, 06:25 PM
dwfronk's Avatar
Default JDM F22B dohc NON VTEC block / H22 dohc VTEC head???
Ok to start this off I bOught this car with a JDM F22B dohc non vtec motor already In it so it's not like I am the one fOrking out the money for It!!!
The timing belt broke right after I got the car and Piston hit valves I am thInkIng of putting a h22 vtec head on the f22 block has anyone done thIs before and what problems do I need to correct?? And if anyone knOws of a butild thread anywhere on the web Please point me to it!¡!¡!¡!¡!
Old 07-17-2012, 09:50 PM
1funryd's Avatar
Default Re: JDM F22B dohc NON VTEC block / H22 dohc VTEC head???
Did you even try and search the forum first? Did you even look at the stickies first? Start there, we all have to learn to be better researchers, its not just handed to us.
Look what I found in the FAQ's at the top of the Prelude forum:
Hybrid/Swaps
All H/F Series Hybrids and CR Thread
F23A Block/H22A1 Head (Accord SOHC VTEC/Prelude DOHC VTEC) by SamIam26
Additional F23/H23 Info by prelittlelude
H23A Block/H22A Head (Prelude DOHC Non-VTEC/Prelude DOHC VTEC)
F20B Destroking Hybrid by satan_srv
F22B2 Block/H22A Head (Accord SOHC VTEC/Prelude DOHC VTEC) by prelittlelude
F23A Block/H23a Head (Accord SOHC VTEC/Prelude DOHC non-VTEC) by PirateMcFred
Official OBDI H22a into OBDII 5th Gen Thread - by 98vtec
H22a4 head onto H22a1 block
F23 Crank Hybrid Engines Thread
I dont mean to sound like a jerk, but you have to do your part on a forum.
Old 07-18-2012, 08:05 AM
dwfronk's Avatar
Not trying to be a jerk But did you read my post in detail??? JDM F22B not a f22a1-2 or F22b1-2. Out of all that stuff you posted nothing in there has anything to do with a JDM F22B block and H22 head combo. I have been searching for days and EVERYTHING I have found sofar is ppl doing the same thing I am doing and trying to see if there is anyone out there that has completed this swap and what problems they have run into!
Old 07-18-2012, 08:31 AM
1funryd's Avatar
So you looked into this swap that I already posted?
Old 08-03-2012, 07:42 PM
tim73's Avatar
DW, Iam in the same boat as you. I have a JDM F22b DOHC non-VTEC, with a snapped timing belt. But all I want to do is get it fixed as is, cheaply as possible. I am runnign into a MAZE of different information. These really are weird engines. ALMOST the same as H23, but not. Same bottom end as F22ax, but theyre not DOHC.
Did you get your problem resolved? If so, please share. I am really looking for a timing set that fits, and a head gasket set that also fits. Plus, I will need to figure out which valves I will have to replace.
I am not looking for performance upgrade at all, just trying to repair with as little impact on my wallet as possible
Plus anybody else, please share! Thanks!
Old 08-04-2012, 05:19 AM
minilogoguy18's Avatar
From what most say the block is identical to the h block, you' end up with a low compression h22.
Old 08-04-2012, 05:37 PM
tim73's Avatar
OK, so i found a f22a1 engine for $350, with a 90 day warranty. Do you guys think it will be cheaper to just replace the JDM F22B, with the A1? Or would it be cheaper to replace timing belt, repair head/valves and head gasket? Thanks!
I am leaning towards the F22a1, which is the engine which originally came in the car.
Also, do you guys think the F22B Is worth anything, if I do pull it out and replace it?
Old 08-04-2012, 07:36 PM
HondaVerno's Avatar
F22 dohc=H23a
-________-
How do people not flame this thread?!? Lol
HondaVerno's Avatar
F22 dohc=H23a
-________-
Old 08-06-2012, 08:11 AM
Steezer's Avatar
Originally Posted by HondaVerno
F22 dohc=H23a
-________-
F22 dohc=H23a
-________-
Old 03-19-2014, 05:03 PM
rayrayrocket's Avatar
The f22b block is an f22 block the head from a dohc f22b and an h23a1 are identical but the h23 does have slightly bigger cams stock everything head gasket up h23a1 block down f22 im new to hondas and I knew this (with the help of a friend that has one pushing over 600hp)
95prelude95
08-24-2016 09:44 AM
Amerazn
08-24-2011 09:10 AM
jdmhonda
02-19-2007 07:25 AM
baddog
09-20-2004 09:21 AM
95lude-s
03-13-2004 09:46 PM
Quick Reply: JDM F22B dohc NON VTEC block / H22 dohc VTEC head???
