f20b???
Old Jun 18, 2012 | 03:48 PM
slipperytuna92's Avatar
Default f20b???
ive researched tons of things on here and i find myself finding so much clashing info about this swap so any input would be greatly appreciated thank you for your time i have a question about the upper motor mount on drivers side im swapping an f20b into a prelude sh that used to have the f22a1 in it. the f20 only came with the mount bracket not the mount itself. people say i should use the h22 motor mount on it is that accurate??? and also about wiring can i use my f22 harness and use a rywire sub vtech harness with a chipped p28 running a f20b base map?? and one more thing im not clear on is the dizzy people say i have to use the h22 dizzy why cant i just use the oem f20b dizzy with a rywire adapter from obd2 to obd1???
Old Jun 18, 2012 | 04:05 PM
minilogoguy18's Avatar
Default Re: f20b???
To put it simply, the F20B is just a smaller displacement H22A, it's an OBD2 engine but since it's JDM the crank sensor will be in the distributor like a USDM OBD1 engine.
Old Jun 18, 2012 | 04:24 PM
Default Re: f20b???
So what are you telling me to do??? Use the theirs adapter and what's your take on the mount
Old Jun 18, 2012 | 04:44 PM
Thepowderblue's Avatar
Default Re: f20b???
I think the f22a mount and bracket will swap right over.
You can reuse your f22 engine harness but you may have to extend a few wires and add wires and you will need to get obd1 injectors or change the plugs on the harness to fit the f20b obd2 injectors and delete the resistor box by twisting all the wires going to it together. Idk about the ecu I would say have a obd1 ecu chipped for it. You will need to do something with the map sensor, The map sensor is in a black box on the firewall if I am not mistaken on your car so you will need to run a vaccum line to it by adding a nipple to where the map sensor bolts on the obd2 tb or just wire up the map sensor that comes on the obd2 tb. You can use a h22 obd1 dizzy and it will plug in to your harness.
Old Jun 18, 2012 | 04:49 PM
Default Re: f20b???
No they will not I have both sets and they are not comparable
Old Jun 18, 2012 | 04:52 PM
Default Re: f20b???
what are you talking about?
Old Jun 19, 2012 | 08:37 AM
Default Re: f20b???
I say convert the engine to obd1, search, it's not like you're being a pioneer with this swap, it's been done plenty of times and first hand info is all over this board.
Old Jun 19, 2012 | 02:42 PM
Default Re: f20b???
ita already converted to obd1 man i have h22 ob1 injectors/alternator and obd1 rywire dizzy adatped so its converted i just need a clarification on the motor mount the f22 mount will not fit on the f20b bracket and the f22 bracket will not fit on the f20b block... people say i need an h22 mount and others say it wont work i wanna know what will work before i go spending money i hardly have...
Old Jun 20, 2012 | 09:23 AM
Apex1972's Avatar
Default Re: f20b???
I do not know for sure but I would think that the H22 mount would be the one to use.
Old Jun 21, 2012 | 05:36 PM
Default Re: f20b???
Just buy an H22 mount, pretty simple since like I said the F20B is pretty much a 2L H22, almost everything from an H22 works on an F20B.
Old Jun 25, 2012 | 07:20 AM
Default Re: f20b???
Ok guys thank you for the input
Old Jun 25, 2012 | 08:42 AM
Default Re: f20b???
You should be able to swap the whole mount and the bracket that bolts to your block if they are different, I know f22 and h22 ones are the same.
guru350
Oct 19, 2011 12:02 AM
Team Highway
Sep 23, 2007 06:24 PM
Luserkid
Dec 9, 2004 10:07 PM
hybrid22l
Jul 12, 2001 04:01 PM
