Small problem with overheating...
I recently, started having a overheating issue on my H22 which is in my 92 Si. The fan switch works like it should but it still overheats. So far, I've replaced the thermostat with an Oem unit also, the water pump is a new Oem unit. I also, swapped out the sender unit with a known working one. The problem seems to be more affected when the lights are turned on. I read somewhere it's possible a loose ground but I have no idea which one. Any input is helpful in trying to help me fix this issue.
Thanks.
Thanks.
Yep. It was causing the temp gauge to read higher than normal. In fact, the fan was working like it should. But, the gauge was off a bit.
Civicuser888
Mar 13, 2009 06:49 AM
electron_si
Sep 19, 2007 04:45 AM
Erik_Pb_Foot
Jun 9, 2003 06:11 AM
