Rod Knock on 1997 H22A4 ~ HELP!
Ok so I need to rebuild my bottom end on my 1997 Prelude SH.
I have a set of NPR Pistons/Rings, But I need to find an OEM full gasket set or atleast an OEM head gasket set, Good Set of bearings, and a new oil pump.
I searched for topics on this but all the links are expired or the companies are out of business. Im mainly concerned about the OEM gasket set.
I'm not trying to do a performance build on it, just stock and maybe some little things for reliability if there is any.
Please help, or point me to some posts with current informaton. Thanks!
Re: Rod Knock on 1997 H22A4 ~ HELP!
Why don't you just go to your local dealer? Most online places seem cheaper but after shipping it usually comes out about the same.
15100-P5M-305 SET PUMP ASSY., OIL $191.26
http://www.hondapartsnow.com/genuine...0-P5M-305.html
12251-P5M-004 GASKET, CYLINDER HEAD $57.25
http://www.hondapartsnow.com/genuine...1-P5M-004.html
12030-P13-000 GASKET SET, HEAD COVER $40.57 (includes vc gasket, sparkplug tube seals, and new grommets)
http://www.hondapartsnow.com/genuine...0-P13-000.html
15825-P13-005 FILTER ASSY., SPOOL VALVE $13.65 (VTEC solenoid gasket)
http://www.hondapartsnow.com/genuine...5-P13-005.html
12513-P30-000 RUBBER, CYLINDER HEAD SEAL $5.24 (cam seal - intake cam trans side)
http://www.hondapartsnow.com/genuine...3-P30-000.html
12210-PZ1-004 SEAL A, VALVE STEM (NOK) $1.08 (intake valve stem seal)
http://www.hondapartsnow.com/genuine...0-PZ1-004.html
12211-PZ1-004 SEAL B, VALVE STEM (NOK) $1.08 (exhaust valve stem seal)
http://www.hondapartsnow.com/genuine...1-PZ1-004.html
ThatGinjaDude
01-03-2017 08:22 PM
