flash codes.. help
Old Jul 11, 2012 | 06:01 PM
mizle's Avatar
Default flash codes.. help
How do i flash codes on my 97 prelude. has jumper harness to convert to obd1. Im using a p28 chipped ecu. the check engine light came on and my scanner isnt picking it up the code. Need help my car has a misfire and is running like Crap!
Old Jul 11, 2012 | 06:09 PM
Hidenplanvew's Avatar
Default Re: flash codes.. help
scanner wont read an obd1 converted ecu... You need to ground the service wire to ground need to look at a wire diagram and find the wire but I think its D4 but I could be wrong on the location
Old Jul 11, 2012 | 06:30 PM
mizle's Avatar
Fund it. its a BLUE 2 wire plug you need to jump its behind the 0bd2 scanner plug. Its hidden but its there.
I got code 3, code 7, and code 14
Old Jul 11, 2012 | 09:07 PM
mizle's Avatar
ok so i switched ecus to my old one and then back to the one i just bought and no MIL. what the f*(&%!
super weird ima see if the codes come back up.
Loyalhondahaver
14
Oct 18, 2013 11:52 AM
Lucky-13
21
Mar 22, 2007 05:27 AM
b18c4dr
Mar 1, 2006 03:09 PM
Daniel-sanB1
10
Jan 5, 2006 10:10 PM
ThaReason
Mar 26, 2004 05:20 PM
