random technology cats.?
Old Aug 17, 2005 | 10:27 PM
Edulerp's Avatar
Default random technology cats.?
worth it? they seem cool but any one got one, make a differnece?
Old Aug 18, 2005 | 04:45 AM
Firedrake's Avatar
Default Re: random technology cats.? (Edulerp)
On a stock or mostly stock car, no way. On a turbo car, they make a big difference and will still let you pass emissions (I passed with 780 cc injectors and a 3 inch random tech cat), but having no cat is the best option (not best for the environment though)
Brian
Old Aug 18, 2005 | 11:47 AM
Edulerp's Avatar
Default Re: random technology cats.? (Firedrake)
im running N/A and i got a few bolt on, it should still do alittle right?haha thanks
Old Aug 18, 2005 | 12:04 PM
gerhard's Avatar
Only if you have a non-stock exhaust.
I got one because it was alot less expensive then the OEM cat... and it is well made.
Old Aug 18, 2005 | 12:35 PM
quadiv20's Avatar
Default Re: random technology cats.? (gerhard)
Is it a direct bolt on, or do you have to weld on the flanges?
-B
Old Aug 18, 2005 | 01:12 PM
batboy1720's Avatar
Default Re: random technology cats.? (quadiv20)
It's direct bolt on no welding need on flange. If you need a used one let me know I have one for sale.
Old Aug 18, 2005 | 02:21 PM
quadiv20's Avatar
Default Re: random technology cats.? (batboy1720)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by batboy1720 &raquo;</TD></TR><TR><TD CLASS="quote">It's direct bolt on no welding need on flange. If you need a used one let me know I have one for sale.</TD></TR></TABLE>
How much?
Old Aug 23, 2005 | 09:24 PM
Edulerp's Avatar
i think they around 250 errr soo...
Old Sep 7, 2005 | 08:48 PM
batboy1720's Avatar
Opps haven't check my watch topics. Please check your IM quadiv20
Old Sep 8, 2005 | 04:56 AM
fast4w$'s Avatar
i have one on my car, It seems to be working well. I used to have a stainless test pipe bolted in. I notice alot of the raspy tone is gone now that i've got the cat in. Sounds alot better.
Old Sep 8, 2005 | 05:42 AM
gerhard's Avatar
Default Re: random technology cats.? (FaS4wS)
I've noticed that the exhaust is a little louder with the Random Cat.
Old Sep 12, 2005 | 08:32 PM
BLKSHLUDE's Avatar
is the random tech cat better than the magnaflow one&gt;? cause i hear both are pretty good. cause i was thinking of getting it on my 5th gen sh and all i got on it now is APEXI N1 exhaust and V2 intake but i plan on installing it once i get mugen headers.
Old Sep 12, 2005 | 10:59 PM
piotrush's Avatar
Default Re: (BLKSHLUDE)
I used to have a carsound cat with my N1 and stock header - made the exhaust a tad throatier yet not much louder (which is good since it was loud enough). I kept throwing CEL 67 though, which got annoying since it deactivated atts, so be prepared to get an o2 sim. right now I have a rage header and Im planning to get a 2.5" cat and mate it to either the N1 or get a 2.5" exhaust from kteller. Not sure which yet.
Old Sep 13, 2005 | 06:48 PM
BLKSHLUDE's Avatar
so by adding a high flow will it alwys deactivate my atts unit? or does it depend on what type of High Flow Cat&gt;
Old Sep 13, 2005 | 07:51 PM
sharkcohen's Avatar
I properly working cat should not cause issues related to code 67. I've had a Car Sound in the past and now have a Random Tech, have had troubles with neither.
Old Sep 13, 2005 | 10:40 PM
xbn83's Avatar
Default Re: (sharkcohen)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sharkcohen &raquo;</TD></TR><TR><TD CLASS="quote">I properly working cat should not cause issues related to code 67. I've had a Car Sound in the past and now have a Random Tech, have had troubles with neither.</TD></TR></TABLE>
Does the cat add any distortion or alter the exhaust sound any at all? And between Car Sound and Random Technology, which one worked better for you and why?
Old Sep 13, 2005 | 10:50 PM
sharkcohen's Avatar
Default Re: (xbn83)
No way I can say which worked better, the Car Sound was a 2.5" diameter piece, the Random Tech I'm using now is a stock replacement (2" diameter) piece.
8OOSTED
Aug 23, 2010 06:56 PM
isaacEK
Jul 11, 2008 01:07 PM
TurBoTeG
Jul 5, 2002 11:06 AM
