Short! :(
Old Aug 18, 2005 | 09:40 PM
PreludeSi94's Avatar
Default Short! :(
ok this just started doing this outta the blue..... everytime i put in a new 15A fuse in for the brake lights/horn it blows as soon as it touches the plug. so i have no brake lights or horn. ive tried a 30a fuse and it blew right away... any ideas on what i should do? is there a way to trace the wires or anything? I'd prefer to do it myself since taking it somewhere to get fixed will cost alot of $$ which i dont have. thanks in advance
Ps. it blows when the horn/brake lights are disconnected and car is off
Old Aug 18, 2005 | 09:48 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: Short! :( (PreludeSi94)
Have you tried any other size fuse, bigger than the 30...Like a 50?
Old Aug 18, 2005 | 09:59 PM
Default Re: Short! :( (AnthonyG2003)
id prefer not to use a bigger size amp fuse considering the 30A blew right away and its not good
Old Aug 18, 2005 | 10:02 PM
steveobb4's Avatar
I would say an open wire somewhere that is hot. I fnn hate electrical gremlins, good luck man. Do you have a shop manual to look at the wiring diagrahms?
Old Aug 18, 2005 | 10:21 PM
Default Re: Short! :( (steveobb4)
nah cant find one... only ones i can find are for 78-82?
Old Aug 19, 2005 | 05:42 AM
The Weather Man's Avatar
Hey. At the fuse panel - you know how the fuse has two prongs right?.....check the voltage of those two slots.....one should be 12v or 11.95+.....and the other should be ZERO.....most likely, the one that's supposed to have ZERO has like .2v or something like that. All that means is that you have a bad ground somewhere......you can try to find that ground - check for an open circuit......or you could try to cheat by cutting that wire(responsible for that slot) and put in a few resistors.....solder them there. I think the fuse is popping because that "ground" is getting too much current. The voltage pressure is outa wack....just a thought....hope it helps.
Old Aug 19, 2005 | 05:46 AM
ALso NEVER go higher than the above stated amps on the fuses.....
Reason why: the circuit can only take in so much current(measured in Amps).....so the fuses' responsibility is to open the circuit when a higher current passes......
so, if you have a 50A fuse there....when its supposed to be 15A.....35A are getting through that circuit - so you're still going to fry the load source(lights, horn) anyway. The resistors job is to hold back a certain amount of current - there are different resistors.
Also, if you put in a higher AMP fuse - you can definately start a fire.....you don't want that....because then, you'll have "SHORTS" everywhere....won't be pretty.
Check your grounds....find out where it is.
Old Aug 19, 2005 | 05:21 PM
chandler's Avatar
check the bulbs in your tail lights, unplug them all then put the fuse in , put them in one by one and check the fuse each time, that will narrow it down
Dru-Si
Mar 21, 2010 06:12 PM
Bobby808
Apr 10, 2005 11:13 AM
wizard9934
Oct 22, 2004 08:18 AM
Rhythm Racer
11
Jun 27, 2003 10:46 AM
