02 sensor voltage....
ok i was just wiring up my wideband... and my buddy cut the 4 wires to my 02 sensor.. and now i cant figure out with wire is wich (ground, ground, heater wire and 02 wire..) does anyone know how to test the wires to tell which one is wish 9 (with a multimeter)
wire colors wont help because its a swap wiring harnes that i got from Hasport
why cant you trace them back from the stock o2 sensor. i can say that there is two wires i believe the same color for the heater. then a gound and the o2.
well those wires are tapped up like a mo fo... but i did get under the car last night and looked at the colors of the wires...
orange with blue stripe
yellow with black stripe
green with white stripe
and a white wire....
i have a book that says yel/black (+) and orn/wht (-) should have 12 volts between them so i guess thats heater. and white and green/white are o2. white goes back to the ecu pin d14. and green/white is common with a bunch of other sensors. orange/ white goes back to the ecu at pin a5. hope this helps
