4WS problem
Old Aug 20, 2005 | 09:49 AM
pez1's Avatar
Default 4WS problem
Hi, i have a 94 JDM prelude 2.2vtec, the 4WS light shows up, but if I disconnect and reconnect battery, problem solved for a while, till its back. I have read the other 4WS thread, but where do I find the error codes that are given?? sorry if this is stupid question. Is my next step to resolder the relay contacts?
Cheers
Pez
Old Aug 20, 2005 | 02:38 PM
AndyD's Avatar
Default Re: 4WS problem (pez1)
I would resolder the contact points. I am very sure that the ECU is the problem.
Old Aug 20, 2005 | 03:12 PM
pez1's Avatar
Default Re: 4WS problem (AndyD)
Thanks! will give it a try Will it help me knowing what error codes are thrown? where are these codes shown?
Pez
Old Aug 20, 2005 | 06:15 PM
a4man's Avatar
my brother had the same problem, but other stuff went wrong and he just sold his car instead of fixing everything
Old Aug 20, 2005 | 06:57 PM
AndyD's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pez1 &raquo;</TD></TR><TR><TD CLASS="quote">Thanks! will give it a try Will it help me knowing what error codes are thrown? where are these codes shown?
Pez</TD></TR></TABLE>
Read this thread. https://honda-tech.com/zeropost?cmd=tshow&id=886363
Mine had the same problem you speak of too. Sometime the 4WS light would stay on all the time. The only way to fix it was by pulling the stereo fuse to reset the 4WS ECU.
Since I changed the 4WS ECU, it works MUCH better. It still throws the 4WS light every once in a while but usually turning the car off and back on fixes it.
Good luck.
HondaPH22
Jul 17, 2006 09:26 PM
Slammin585
May 24, 2006 09:54 PM
sleepyEK
Aug 1, 2005 04:46 PM
Chronicsinners
35
Jan 28, 2005 04:35 AM
B18C-EJ1
Jul 24, 2003 05:16 PM
