solid motor mounts found... kinda
Old Aug 20, 2005 | 01:23 PM
flip1199's Avatar
Default solid motor mounts found... kinda
http://www.enjoracing.com/engine_mounts_swap.html
too bad they cost $510 and only for 4th gens...
Old Aug 20, 2005 | 01:53 PM
PrecisionH23a's Avatar
Default Re: solid motor mounts found... kinda (flip1199)
Pretty nice... the only problem I see is the front motor mount. It will disable the use of the radius rods.
Old Aug 20, 2005 | 02:07 PM
The Phil's Avatar
Default Re: solid motor mounts found... kinda (PrecisionH23a)
http://www.enjoracing.com/engine_mounts_oem.html
I don't see how those would disable the use of radius rods.
And they have a PN for 5th gens as well.
EDIT: the link you posted was for swapping H series motors into the 92-96 preludes, not for OEM replacements. The link above is for the OEM upgrades, which appear to be direct replacements for the stock mounts, as well as available for both the 4th and 5th generation preludes.
Old Aug 20, 2005 | 02:17 PM
The Birdman's Avatar
Default Re: solid motor mounts found... kinda (The Phil)
^^good call. I have the enjo oem replacement mounts. They are really nice in my opinion.
Old Aug 20, 2005 | 02:52 PM
The Phil's Avatar
Default Re: solid motor mounts found... kinda (jd3jdm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jd3jdm &raquo;</TD></TR><TR><TD CLASS="quote">^^good call. I have the enjo oem replacement mounts. They are really nice in my opinion.</TD></TR></TABLE>
Any problems? Excessive vibration?
They don't seem to make a mount to replace the tranny mount. Any downsides to that?
Old Aug 20, 2005 | 02:58 PM
flip1199's Avatar
so what's the difference between the swap mounts and oem replacements? arent' the mounts the same for h23/h23/f22?
Old Aug 20, 2005 | 03:14 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The Phil &raquo;</TD></TR><TR><TD CLASS="quote">
They don't seem to make a mount to replace the tranny mount. Any downsides to that?</TD></TR></TABLE>
If you look on enjo's site http://www.enjoracing.com/engine_mounts_oem.html and click on the part number for "honda prelude 92-96" and look under the "Includes" section at the bottom of the pop-up window, you will see that it comes with both the tranny mount and the rear tranny mount. Vibration is a bit more than normal but nothing bothersome. The most noticeable is right when you start the motor, it vibrates more in the initial cranking of the motor but after that, fine. No problems whatsoever.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">so what's the difference between the swap mounts and oem replacements? arent' the mounts the same for h23/h23/f22?</TD></TR></TABLE>
The difference is that the swap mounts are made for engines going into cars they don't originally come in. example: h22 into a civic.
The oem replacement mounts are made of the same material and are the same mounts, they are just made to go in the vehicle that the motor originally came in.
Old Aug 20, 2005 | 03:45 PM
flip1199's Avatar
but if you look at the swap mounts they have mounts to fit a h-series into a 92-96 prelude which it already came with. so wouldn't that be the same as the oem replacement?
Old Aug 20, 2005 | 04:33 PM
Hawkze_2.3's Avatar
Yeah, I've seen these advertised for a while, but no one seems to actually have them in stock, or is able to provide pictures of them. If they were actually available I would consider them....
Maybe someone can find a dealer that has them.
Old Aug 20, 2005 | 04:57 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 &raquo;</TD></TR><TR><TD CLASS="quote">but if you look at the swap mounts they have mounts to fit a h-series into a 92-96 prelude which it already came with. so wouldn't that be the same as the oem replacement?</TD></TR></TABLE>
As far as I know, they would be the same damn thing. I guess they could consider it a motor swap that you took an f22 or h23 out of your 92-96 lude and replaced it with an h22. I'm sure that's what they mean, as dumb as it sounds. They are the same mounts.
Old Aug 21, 2005 | 05:57 AM
The Phil's Avatar
Default Re: solid motor mounts found... kinda (Hawkze_2.3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hawkze_2.3 &raquo;</TD></TR><TR><TD CLASS="quote">Yeah, I've seen these advertised for a while, but no one seems to actually have them in stock, or is able to provide pictures of them. If they were actually available I would consider them....
Maybe someone can find a dealer that has them. </TD></TR></TABLE>
I could call them sometime this week, see if anybody wants to get a GB started...
Old Aug 21, 2005 | 06:04 AM
DcWest's Avatar
i am happy with my inserts.
Old Aug 21, 2005 | 07:17 AM
mgags7's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jd3jdm &raquo;</TD></TR><TR><TD CLASS="quote">If you look on enjo's site http://www.enjoracing.com/engine_mounts_oem.html and click on the part number for "honda prelude 92-96" and look under the "Includes" section at the bottom of the pop-up window, you will see that it comes with both the tranny mount and the rear tranny mount. Vibration is a bit more than normal but nothing bothersome. The most noticeable is right when you start the motor, it vibrates more in the initial cranking of the motor but after that, fine. No problems whatsoever.
The oem replacement mounts are made of the same material and are the same mounts, they are just made to go in the vehicle that the motor originally came in.</TD></TR></TABLE>
haha good call on the "experience" with them john.....
anyways they look like good stuff....just pretty expensive...
Old Aug 21, 2005 | 09:16 AM
Default Re: solid motor mounts found... kinda (mgags7)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mgags7 &raquo;</TD></TR><TR><TD CLASS="quote">anyways they look like good stuff....just pretty expensive...</TD></TR></TABLE>
^^ True you just have to decide whether or not they are a neccessary piece for your setup.
The energy suspension inserts are nice too. Matt knows about them. They really help alot.
Hharrishonda
Aug 7, 2008 07:49 AM
Wazup
Oct 18, 2007 10:14 AM
oneprelude
Sep 18, 2007 08:14 PM
vinuneuro
Mar 16, 2007 03:56 PM
whitelightning
Nov 17, 2006 07:07 AM
