Starting Problem!!!!!!!
Old Aug 18, 2005 | 06:42 PM
FalconMan's Avatar
Default Starting Problem!!!!!!!
I have a 92 si and when i try to start it...it just clicks once and nothing happens.....any help?..
oh and i changed plugs also and tried a new dist. cap...
Old Aug 18, 2005 | 06:46 PM
onefastrx7turbo's Avatar
Default Re: Starting Problem!!!!!!! (FalconMan)
sounds like battery or starter solenoid. check the battery. if it will start jump starting, its the battery. if you short the solenoid on the starter and it cranks, its the starter.
neil
Old Aug 18, 2005 | 07:01 PM
FalconMan's Avatar
Default Re: Starting Problem!!!!!!! (onefastrx7turbo)
jumping did not work
Old Aug 18, 2005 | 07:13 PM
1epmugenlude's Avatar
Take a look at your terminals that connect to your battery they may be dirty/corroded or a bad connection.
Old Aug 18, 2005 | 08:08 PM
FalconMan's Avatar
Default Re: (1epmugenlude)
i mean all accessories work...could it still be the battery...and plus it is only a year old....
Old Aug 18, 2005 | 08:12 PM
Hey check those connections...My cables were dirty and not connected good and I had all accessories working, but it just wouldn't start. just a click..clickk
Old Aug 18, 2005 | 08:13 PM
FalconMan's Avatar
ok thanks.... ill do that real quick
Old Aug 18, 2005 | 08:41 PM
any luck
Old Aug 19, 2005 | 06:02 PM
FalconMan's Avatar
and the verdict is in...bad starter......took 2 hours to take out...go to the store and put the new one in....yup yup
jgett002
Aug 3, 2016 02:00 PM
DeleriouS25
Oct 1, 2008 06:40 AM
SiB16A
Jun 11, 2006 12:37 PM
85DX
Jan 9, 2005 12:46 PM
