Collector mod
Old Aug 17, 2005 | 03:33 PM
Htwentytwoforme's Avatar
Default Collector mod
I've seen a lot of posts about modifying the collector on a header but i'm not sure exactly what the collector is even after reading many posts about it. Is the collector on the header or the downpipe?
Old Aug 17, 2005 | 08:36 PM
Jordans95si's Avatar
Default Re: Collector mod (Htwentytwoforme)
its where the 4 pipes come together, bro
Old Aug 17, 2005 | 10:08 PM
ludeR917's Avatar
here you go dude. this is a dc header. i heard good things about the greddy header with this mod.
Old Aug 18, 2005 | 01:16 PM
Default Re: (ludeR917)
so you have to cut the flanges off both pieces, the header and the downpipe where they meet and put bigger ones on?
Old Aug 18, 2005 | 01:25 PM
DJ_SaNdOz's Avatar
https://honda-tech.com/zerothread?id=1226335
That may help you....
Old Aug 18, 2005 | 08:47 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ludeR917 &raquo;</TD></TR><TR><TD CLASS="quote">here you go dude. this is a dc header. i heard good things about the greddy header with this mod.
What if you want to keep the flex pipe? So all you have to change is the downpipe, nothing needs to be done to the header?
Modified by Htwentytwoforme at 10:37 PM 8/18/2005
Old Aug 18, 2005 | 09:45 PM
foshizllmynizl's Avatar
Default Re: (Htwentytwoforme)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Htwentytwoforme &raquo;</TD></TR><TR><TD CLASS="quote">What if you want to keep the flex pipe? So all you have to change is the downpipe, nothing needs to be done to the header?
Modified by Htwentytwoforme at 10:37 PM 8/18/2005</TD></TR></TABLE>
flex pipe also comes in diff. sizes, so you would need a 2.5in ID flex pipe which can be found at the K teller site.
Old Aug 18, 2005 | 10:07 PM
Default Re: (foshizllmynizl)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by foshizllmynizl &raquo;</TD></TR><TR><TD CLASS="quote">flex pipe also comes in diff. sizes, so you would need a 2.5in ID flex pipe which can be found at the K teller site.</TD></TR></TABLE>
So do i need to bring the flex pipe and flanges to the muffler shop or will they already have all the necessary parts? And the 3 bolt flanges they have on the kteller site, those are the exact same ones that come on the DC downpipe and will bolt right up to my exhaust?
Old Aug 19, 2005 | 05:47 AM
JTCdudeman's Avatar
Master H Technician
This was done with parts from Autozone. $8 in parts to be exact. Its TIG welded and the welding looks better in person than the pics. In person the welding is perfect. You can clearly see the size difference with the two collectors next to each other in this pic.
Old Aug 19, 2005 | 08:51 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Htwentytwoforme &raquo;</TD></TR><TR><TD CLASS="quote">So do i need to bring the flex pipe and flanges to the muffler shop or will they already have all the necessary parts? And the 3 bolt flanges they have on the kteller site, those are the exact same ones that come on the DC downpipe and will bolt right up to my exhaust?</TD></TR></TABLE>
bump
Old Aug 22, 2005 | 12:07 PM
Old Aug 22, 2005 | 12:38 PM
IHateJDM's Avatar
that depends on the shop, but most do. call and ask. If the flanges aren't right, they can chop one off and weld a new one on in a few seconds.
Old Aug 22, 2005 | 12:52 PM
What are the disadvantages, if any, to ditching the flex pipe when doing this mod?
Old Aug 22, 2005 | 01:00 PM
IHateJDM's Avatar
What are the disadvantages, if any, to ditching the flex pipe when doing this mod?</TD></TR></TABLE>
it doesn't matter. as long as you have either the spring bolts on your flanges or a flex pipe, you'll be fine. Its just to keep your exhaust from breaking if it gets hit.
Capo dei Capi
Dec 6, 2007 08:06 PM
MenaceL.A.671
Oct 4, 2007 11:36 PM
h22aBB4
Jan 2, 2007 09:09 PM
4175017
Sep 4, 2006 05:47 PM
solfood
Jan 19, 2006 12:53 PM
