what to do with.....
Old Dec 3, 2005 | 03:27 PM
sparknock's Avatar
Default what to do with.....
my buddy danny has a 86 prelude that we turboed. now the head gasket is leaking oil. we haven't seenany oil in the coolant or coolant in the oil. my question is what is offered for this typ of motor (BT) iirc. i couldn't find any thing in the ARP catuloge. we really want to ''stud'' this block. the car is running about 9 psi of boost. the motor is completely stock. well except the accel 255cc injectors (witch is more than enuff fuel). i was trying to get him to do a motor swap but i'm not sure what fits (me being a vw owner and all). any info would be great. thanks for looking at this post
-mike
Old Dec 3, 2005 | 09:46 PM
1GPlusSH's Avatar
Default Re: what to do with..... (sparknock)
I know it's not part of your question...but 255cc injectors? If you're pushing 9psi on an average size turbo, it seems like you'd be getting pretty high on those injectors' duty cycle. 255cc injectors in a 4 cylinder are good for a little over 200 crank horse. If you've had it dynoed, which I hope you have, and you were around 165 whp, I'd look into getting some more injectors so that you aren't detonating. Definitely get it tuned if you haven't; it's going to have more power and last longer.
I don't know about a swap.
Old Dec 3, 2005 | 11:22 PM
dohcVTECeg2's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GPlusSH &raquo;</TD></TR><TR><TD CLASS="quote">I know it's not part of your question...but 255cc injectors? If you're pushing 9psi on an average size turbo, it seems like you'd be getting pretty high on those injectors' duty cycle. 255cc injectors in a 4 cylinder are good for a little over 200 crank horse. If you've had it dynoed, which I hope you have, and you were around 165 whp, I'd look into getting some more injectors so that you aren't detonating. Definitely get it tuned if you haven't; it's going to have more power and last longer.
I don't know about a swap.</TD></TR></TABLE>
Old Dec 4, 2005 | 05:20 AM
sparknock's Avatar
Default Re: what to do with..... (1GPlusSH)
he has a MSD6 btm. detonation is not a problem. the air/fuel meter never leans out. we had my good friend john put it on his LM1 and under boosts it stay at 11.6. isn't 14.7 like the perfect air fuel ratio? what compression is his motor at? could we put two stock head gaskets on this motor to lower the compression ratio?
Old Dec 4, 2005 | 11:17 AM
Chief Brody's Avatar
Do it right the first second time!
Community Builder
Active Streak: 30 Days
Default Re: what to do with..... (dohcVTECeg2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dohcVTECeg2 &raquo;</TD></TR><TR><TD CLASS="quote"> </TD></TR></TABLE>
Is that all you know how to do? Quote what someone said and then give them a thumbs down? I have looked at like 5 threads today with you doing that ****. How about giving a reason as to why you disagree with what someone said?
Old Dec 4, 2005 | 05:53 PM
sparknock's Avatar
hey guys we found a swap. i think its a b16 out of a 2000 si civic with tranny, wire harness, and pcm for $1,600 low milage 30k or so. is this worth it? as for the thumbs down guy. get a life bro i'm just tring to help a friend out, and if you dont have any thin nice to say then dont post.
Old Dec 7, 2005 | 02:56 AM
sparknock's Avatar
r33dm0n3y
Sep 1, 2009 10:11 PM
tarheelsoldier
Mar 28, 2007 11:44 AM
mike70845
Jun 25, 2005 07:53 PM
Tegra
Nov 30, 2002 05:20 PM
Hybrid
Aug 8, 2002 02:59 AM
