questions about alignment
Old Dec 3, 2005 | 09:22 PM
PreludeX24's Avatar
Default questions about alignment
i have a '98 prelude lowered on h&r sports. And i've basically had it lowered for about 1 and a half year. But recently i noticed that the inner part of my tire was wearing down more than the outside.
h&r sports are 1.4" drop all around. I believe that shouldn't cause much of a camber problem. But i had hit a curb one time pretty hard, and big bumps on the road every once in a while.
i finally took it into sears to get an alignment today, they told me that they can't do anything with the camber since it is lowered, so i just told them to zero out my toe.
I got the print out but i can't tell if it was my toe that caused my tire to wear down prematurely. Sears said my camber is just a bit off.
Here is the print out:
Old Dec 4, 2005 | 06:38 AM
PreludeX24's Avatar
bump
Old Dec 4, 2005 | 08:47 PM
The Weather Man's Avatar
Oh yeah - from the looks of that. Your toe was out of wack. And TOE angles do wear out tires prematurely.
Although your before total toe was in range - your individual toe was still out of range.
And yes, it happens all the time.
For instance - if the total toe is supposed to equal 3*..........
You can have the following R and L combinations
-2* 5*
-1* 4*
4* -1*
.....etc....................
Total toe isn't something to be WORRIED about..........individual toe is more important. Just try to get the toe the closest to spec as possible and total toe will fall in place.
Old Dec 4, 2005 | 08:52 PM
You might want to look into a camber kit also - because your camber is off as you can see.
Caster is a bit of - but you probably won't notice a difference when its fixed.
Old Dec 5, 2005 | 09:31 AM
PreludeX24's Avatar
Default Re: (TheKINGPin)
thanks for the reply!
but is the camber off a lot or is it not off enough to really mess up my tires?
would the camber just go off all of a sudden? or does it just happen when you first drop it?
Old Dec 5, 2005 | 11:13 AM
yOnKiNaToR's Avatar
Default Re: (PreludeX24)
i wouldn't worry about the camber. it won't wear it significantly if toe is in line. if u still have some wear on the inside have your tires remounted the other way on the rim so u can wear the outside of the tires and keep the tires longer.
Old Dec 5, 2005 | 11:48 AM
PreludeX24's Avatar
thanks for the replies guys!
Old Dec 5, 2005 | 12:22 PM
95PreludeSi's Avatar
Default Re:
yep, camber is fine. Toe is what's eating your tires up. I don't understand why people try to get rid of camber. -2 degrees is good.
Old Dec 6, 2005 | 02:00 PM
yOnKiNaToR's Avatar
Default Re: Re: (95PreludeSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95PreludeSi &raquo;</TD></TR><TR><TD CLASS="quote">yep, camber is fine. Toe is what's eating your tires up. I don't understand why people try to get rid of camber. -2 degrees is good.</TD></TR></TABLE>
i kind of agree with that. 2 degrees is good in front but i would rather much less in the rear - at least for our understeering preludes anyway.
Rob91DA
Northwest
Feb 15, 2011 06:15 AM
97EXB18C
14
Jul 28, 2005 09:05 PM
justininhifi
Jun 27, 2003 10:46 PM
Phat Corolla
Jan 17, 2002 08:50 AM
kikkoboyie
Sep 17, 2001 04:26 AM
