weird idle problem
i'm kinda thinking its not a vac leak anymore but wondering if you guys have any suggestions
the car idles fine. solid, does not fluctuate. but when i rev the motor up to lets say 3k then let off, the rpms drop real low , prolly around 500 rpm the motor starts to spit and shake like its about to die.. then goes back up to regular idle like nothin...
i have no idea. plugs/ wires are new
cap/rotor going on tomorrow with fuel filter
ideas?
ideas?
Mine will do this sometimes too( only in cold weather). I think the iac uses a wax pellet and maybe the temperature is affecting it, just a thought.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The_Sober »</TD></TR><TR><TD CLASS="quote">did you put a lighter flywheel in it?</TD></TR></TABLE>
no. stock flywheel
no. stock flywheel
I think i mine may be the IACV as well.. is this something i can fix myself? or should i just take it to a mechanic? if i cant do it myself what should i look for? my idle goes from like 1400 to about 2400 i dunno? ne suggestions?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueLude 94 »</TD></TR><TR><TD CLASS="quote">my car use to go up and down from 500 to 1500 at idle. It was my iacv.</TD></TR></TABLE>
Exactly what mine would do, and i also cleaned the iacv and it fixed it perfectly
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueLude 94 »</TD></TR><TR><TD CLASS="quote">my car use to go up and down from 500 to 1500 at idle. It was my iacv.</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by CliffBurton »</TD></TR><TR><TD CLASS="quote">
Exactly what mine would do, and i also cleaned the iacv and it fixed it perfectly</TD></TR></TABLE>
HAHAHA, That is exactly what mine would do...I also cleaned out the IACV and it DIDN'T help!
98cwitr
Jan 22, 2004 06:31 PM
