ACT clutch problem?
Old Nov 30, 2005 | 09:08 AM
Black98sh's Avatar
Default ACT clutch problem?
I recently had an ACT clutch(heavy-duty plate with the street disc) installed in my 98sh and i was hoping those with the same setup could let me know how there's has been. The problem is this, after I got the car back I noticed that it was leaking what looked to be transmission fluid so I brought it back to the mechanic who claims that he replaced a seal. The car continued to leak. It has since stopped leaking, but since the end of the break-in period the peddle has gotten very light, as light as stock if not lighter. The mechanic told me this was normal. I purchased this clutch under the assumption that it would have a heavier feel and so far that has not been the case. I fear that choosing the cheapest mechanic is my #1 problem. My question: Is what I'm experiencing normal or does this mechanic have something to fix?
Thanks, Tom
Old Nov 30, 2005 | 12:34 PM
The Weather Man's Avatar
Try to find where the leak is......
But yeah, mine is just as soft as the normal clutch.
Old Dec 1, 2005 | 03:52 AM
DTPrelude's Avatar
im on my second one. love the clutch. no way is it soft as stock. try bleeding ur clutch more. maybe thats ur problem.
Old Dec 1, 2005 | 04:37 AM
mgags7's Avatar
choosing the cheapest mechanic is never the cheapest choice
lol....it comes back to bit you in the ***
Old Dec 1, 2005 | 04:39 AM
specialedition's Avatar
Default Re: (mgags7)
my act clutch felt easier to push in then my stock clutch... the leak could be a seal or the transmission having too much fluid in it.....
Old Dec 1, 2005 | 11:33 AM
Black98sh's Avatar
Default Re: ACT clutch problem? (Black98sh)
I was thinking about bleeding the clutch again, but when I initially got the car back the clutch felt great. It wasn't until I put on a couple hundred miles that it got light. That said, could anything else cause the clutch to be soft/light other then air in the line?
Thanks for the replies,
Tom
egekreject
Mar 12, 2007 06:44 AM
o'malley_808
Nov 10, 2005 07:51 PM
NighthawkR184
Dec 8, 2001 10:27 AM
