cam gears on stock cams
getting tuned with a p72 and hondata system and getting into my manual tensioner conversion ..would it be worth it to put cam gears in then to or should i wait till i get some crower stage 2 cams
Re: cam gears on stock cams (RC's ride)
I don't know how badly tuned it was before the dyno, but I got 12 whp with cam gears with stock cams and a slight advance on timing. I lost a little mid-range torque to get the extra horses. Before tuning: 158 whp, after: 170 whp. Thats with I/H/E/cam gears/ underdrive pullies. Not that great, but an improvement.
Re: cam gears on stock cams (wannabe)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wannabe »</TD></TR><TR><TD CLASS="quote">I don't know how badly tuned it was before the dyno, but I got 12 whp with cam gears with stock cams and a slight advance on timing. I lost a little mid-range torque to get the extra horses. Before tuning: 158 whp, after: 170 whp. Thats with I/H/E/cam gears/ underdrive pullies. Not that great, but an improvement. </TD></TR></TABLE>
my money is on the advance of timing. cam gears allow u to move the powerband up or down.
Re: cam gears on stock cams (flip1199)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 »</TD></TR><TR><TD CLASS="quote">
cam gears allow u to move the powerband up or down.</TD></TR></TABLE>
They also allow you to adjust your overlap.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RC’s ride »</TD></TR><TR><TD CLASS="quote">if i'm going in there to do my manual tensioner how much harder is it to put these on just a couple bolts ehh!!!</TD></TR></TABLE>
make sure you get keyways cause the stock cam gears have them built in.
Re: cam gears on stock cams (DcWest)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DcWest »</TD></TR><TR><TD CLASS="quote">
make sure you get keyways cause the stock cam gears have them built in. </TD></TR></TABLE>
really?
Never seen that before.
really?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DcWest »</TD></TR><TR><TD CLASS="quote">make sure you get keyways cause the stock cam gears have them built in. </TD></TR></TABLE>
firstly keyways are the things in the camshafts and in the gears....the keys are seperable from both....
#35 is the key....seperable.....your gears probably just had them stuck in....
ps. please excuse me if my grammar or spelling is wrong.......etc
Re: cam gears on stock cams (jd3jdm)
i'll also have to hack the cam gear cover to get constant access to them for tunning whats the best way to do this a dremel or what ???
Re: (mgags7)
i've seen people cut circles in the front and on other engines the whole cover is removed but i don't think you can do it that way with h22s because the valve cover and cam gear cover r one...correct me if i'm wrong ..how have you guys done it.. SEEEYAAA
one local guy gained a respectable amount of horsepower from cam gears on a stock-cam'd H22. As said above, playing with the overlap can move the powerband.
And to Skunked: according to my Dyno program says you will only gain about 1 HP with every degree of advance you run.
Re: (LudeyKrus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LudeyKrus »</TD></TR><TR><TD CLASS="quote">
And to Skunked: according to my Dyno program says you will only gain about 1 HP with every degree of advance you run.</TD></TR></TABLE>
That's about right.....
I think it was +2 IN, -1 EX on the stock cams.
