header studs
Old Dec 5, 2005 | 08:47 AM
shutta's Avatar
Default header studs
one of the nuts got a bit rounded trying to get it off, should I cut the nut off and try to get teh stud out with vice grips or what?
woudl autozone or anything like that sell extra studs or would I have to go to honda for them? I want to replace them all as well as teh gasket
Old Dec 5, 2005 | 10:35 AM
brolli's Avatar
Default Re: header studs (shutta)
your probably oging to have to cut it off. you can try vice grips but i doubt it will work. if you have to cut it off, after you remove the header, heat up the head around the stud and after its fairly hot, press a piece of paraffin wax to the head where it meets the stud. although this may not sound very effective, it does help. if at all possible, get ahold of a twist socket---
http://buy1.snapon.com/catalog...talog
and remove it. twist sockets are the ****. if that doesnt work, drill it out and use a helicoil.
Old Dec 5, 2005 | 10:37 AM
brolli's Avatar
Default Re: header studs (brolli)
i would buy the studs from honda. becuase exhaust studs are under a lot of stress. they are probably a little higher quality.
Old Dec 5, 2005 | 02:18 PM
AndyD's Avatar
Do you have access to the bolt-out socket set by Craftsman? It is a GREAT way to remove stripped bolts.
If you cut the bolt off and damage the threads/stud, you will have to drill it out and just put a whole screw/bolt combination.
Old Dec 5, 2005 | 06:49 PM
InvaderTrax's Avatar
Warm up the bolt and touch a candle to it. It'll suck the wax right into the threads. Then clean off any surface wax on the nut and use some vice grips to get it off. Should work
Old Dec 5, 2005 | 06:57 PM
mgags7's Avatar
dont waste your money on new studs....thats retarded...
and being that the stud sticks about an inch out....i doubt you could ever drill it out....
get some of the craftsman extractors like andy said...you will use them for other things, trust me....
just get one from a junkyard or something if you need a new one...but if it was me, i would just run a tap/die through the threads and over the stud when im done....
Old Dec 6, 2005 | 12:45 PM
soundbomber's Avatar
Default Re: (mgags7)
can the exhaust side studs be backed out like the intake side?
Old Dec 6, 2005 | 02:53 PM
BlueLude94's Avatar
Default Re: (soundbomber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by soundbomber &raquo;</TD></TR><TR><TD CLASS="quote">can the exhaust side studs be backed out like the intake side?</TD></TR></TABLE>Yes, when removing my header the right lower stud-nut comes out of the head together
Old Dec 7, 2005 | 10:34 AM
brolli's Avatar
yea...uhm...i would hope that he wouldnt start drilling at the end of the stud. i mean anybody with any common sense would cut the stud off flush with the head before they drilled it out.
Old Dec 7, 2005 | 10:36 AM
brolli's Avatar
Default Re: (brolli)
new studs = less chance you will have to go through this process again. preventative maintenance.
Old Dec 7, 2005 | 10:49 AM
shutta's Avatar
i ended up taking a chisel and pounding a groove in the nut, then hit the groove at an angle until the nut loosened. presto.
gsrkid24
Sep 3, 2009 05:11 PM
jdmpremonition
Feb 26, 2006 02:06 AM
Liquidgsr
Mar 7, 2005 09:17 AM
Jdmglenn
Jan 31, 2005 09:50 AM
rice_classic
Aug 25, 2004 11:30 PM
