SH transmisison?
Old Dec 5, 2005 | 07:38 AM
ekim952522000's Avatar
Default SH transmisison?
Can I put a base transmission in a SH?
Old Dec 5, 2005 | 07:48 AM
98TypeSH's Avatar
Default Re: SH transmisison? (ekim952522000)
Yes and no. You need to fabricate a bracket for the halfshaft. im sure someone else will chime in with pics. No its not a direct drop in swap without the bracket.
Old Dec 5, 2005 | 08:05 AM
Default Re: SH transmisison? (98TypeSH)
would anyone be willing to sell me a bracket?
Old Dec 5, 2005 | 10:25 AM
1GPlusSH's Avatar
Do you have the atts unit on there, or did you take it off? Both transmissions hook up to either block...I had to get another transmission for mine when I had the atts unit on, and I got it from a base model lude.
There is a piece that comes on the SH transmission that you will need;it sits inbetween the atts and the transmission. You have to be careful taking it off. If I can find pics of when I did this, I'll post them.
To switch between a half shaft and an atts unit, either way, you will need to get a bracket. If you are taking off the atts unit, which I doubt from your question, I have a bracket that I made to fit under the half shaft so that you can bolt the half shaft to the SH block....I hope all of this sounds right; it did in my head.
beserious24
Jun 19, 2011 12:05 AM
gnxpro24
Jan 2, 2011 08:44 AM
eric416
Jul 3, 2008 10:33 AM
kornerk12
Mar 28, 2007 08:42 PM
mztykal
Honda Civic (2006 - 2015)
Apr 7, 2006 04:49 AM
