need help asap
Old Mar 14, 2006 | 01:44 PM
championshipwhite93si's Avatar
Default need help asap
driving to work today and long story short i ran out of gas. put gas in the car and it wouldnt start still. listened for fuel pump and it wasnt clicking so i replaced that.. still no clicking to indicate it being on. i dont know whats wrong. im thinking maybe main relay but all my dash lights are working and the car is cranking, it just wont fire. pretty sure it has spark just no fuel.. for the record its a 93 prelude si, h23.. need some opinions fast guys.. also no cel... tried fishing for a code and nothing came up... dont know if that helps.
Old Mar 14, 2006 | 01:47 PM
tayhas's Avatar
Default Re: need help asap (championshipwhite93si)
change the main relay, and check your fuses. the old fuel pump can cause the fuse to blow.
Old Mar 14, 2006 | 01:54 PM
Default Re: need help asap (tayhas)
stupid question. where the hell is the main relay, i know on my old civic and gsr it was the brown relay under the dash. i can hear it click when i crank the car but cant get at it to see it.
Old Mar 14, 2006 | 02:13 PM
MilanoLude's Avatar
It's under the dash on the driver's side. Looks like this
Old Mar 14, 2006 | 02:19 PM
hu's Avatar
hu
I agree. It sounds like the main relay.
Old Mar 14, 2006 | 04:31 PM
thanks for the quick replies.. im going to honda tommorrow to order it, since our advanced auto and autozone are gay and dont have it..
Old Mar 14, 2006 | 04:33 PM
Pullig's Avatar
check it by turning on the key and when the check engine light comes on it should come on and then click off . If it doesnt click off then its ur main relay.
Old Mar 14, 2006 | 04:53 PM
blueBB4lude's Avatar
if the car is cranking then it wouldnt be the main relay. I could be wrong? but i thought that no cranking or anything was a result of a dead main relay
Old Mar 15, 2006 | 02:42 AM
Default Re: (silverlude15)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by silverlude15 &raquo;</TD></TR><TR><TD CLASS="quote">the main relay sends fuel to the injectors to start up the car. without it working, theres no fuel to start up the car, and therefore no startup.
you can hear it when you turn on the ignition. it goes...whiiineee....clunk. then you are set. if you can't hear that, then your relay is bad.</TD></TR></TABLE>
thats exactly what its doing...
tfeagley
Feb 8, 2014 03:34 PM
brandonDAvid
Feb 12, 2011 11:40 AM
92redhatch
38
Aug 3, 2006 04:51 PM
wowverycool
May 17, 2006 06:20 PM
wambus
Feb 12, 2004 08:40 PM
