help
Old Mar 14, 2006 | 04:30 PM
nelsond's Avatar
Default help
93 accord unable to select gears while car is running but when you turn the car off it goes in gears like its nothing could it be the master or slave clylinder or both cause i put
in a new clutch and flywheel and it drove fine for a day but now i cant get it to go in gear to move it and fluid is in the master clyinder but when i went to the car the pedal was on the floor and if it is a leak where would i t go i dont see no trace of fluid on the ground at all you guys are the pros so thats why i ask
ps feels like when i push the clutch it does not even move and i bleed the lines 8 times
and still no go
Old Mar 14, 2006 | 04:53 PM
The Weather Man's Avatar
Its the slave cylinder. Bleed it - thats what you're supposed to do after you put in a new clutch and flywheel. The same thing happened to me - kinda.
Old Mar 14, 2006 | 04:58 PM
prelude1897's Avatar
Default Re: help (nelsond)
You either need to bleed the system, or just replace the slave and master cyclinders. If you change one, you should change the other
Old Mar 14, 2006 | 05:00 PM
Yeah. I think he just needs to bleed the slave cylinder.
You do know how to bleed it correct?
Old Mar 14, 2006 | 05:28 PM
AnthonyG2003
Guest
Posts: n/a
Default Re: (The Weather Man)
Bleed it...
Old Mar 15, 2006 | 10:54 PM
Skidtron89's Avatar
One other possibility is incorrectlt installed throwout or release bearing. I have seen this many times unfortunately on customers cars that decide to change the clutch themselves because me charging $200 must seem like too much I guess.
Old Mar 16, 2006 | 05:42 AM
What was your bleeding procedure? Did you have a friend with you?
Ashwell33
Transmission & Drivetrain
Feb 15, 2019 11:54 AM
ricerEJ8
Feb 23, 2008 04:04 PM
Problemo
Oct 13, 2005 01:12 PM
IntEGNYC
Nov 23, 2003 11:33 PM
