compression test
Old Mar 13, 2006 | 09:34 AM
4thgenner's Avatar
Default compression test
ok i did a compression test about a month ago and forgot to hold the throttle open and only pulled 1 plug at a time.
came back
185--185--185--185
today i redid the test, pulled fuel pump fuse, held throttle at WOT, and all the plugs were out.
came back
190--205--200--205
is this ok for a 7psi boost setup? i am thinking of boosting within a couple months. number 1 cylinder kinda scares me but i still think its ok.
after that i threw a bit of oil in cylinder 1 just to see what kinda result i would get and
Old Mar 13, 2006 | 09:52 AM
The Weather Man's Avatar
Perfectly fine. Honda specs says that a cylinder cannot be more than +/- 28 psi off from another cylinder. You're fine.
In edmunton austrailia?.........anyway.
High is 81 degrees with 60% chance of rain. Low is 76 degrees with 60% chance of rain. Not much change at all. So, what you're seeing now - will be all day basically.
Old Mar 13, 2006 | 10:43 AM
4thgenner's Avatar
edmonton alberta
i wish it was 81 degrees lol
gmon
May 7, 2013 11:14 PM
delsolo95
Apr 3, 2013 08:49 AM
negusjuda
Aug 8, 2011 02:44 PM
Jagan'92
Jul 8, 2004 07:51 AM
Chubz
Jun 27, 2002 02:00 PM
