battery light on
Old Mar 12, 2006 | 04:53 PM
wrx'n you's Avatar
Default battery light on
last night i was on the freeway and did a roll on against a 3000gt vr4 in my h22a ek and after i backed off, my battery light went on for some reason but the car was still running and everything. I pulled over and turned the car off and then back on but the light wass till there. anyone know what that means or why its there? No CEL's either. thanks
Old Mar 12, 2006 | 06:09 PM
AndyD's Avatar
Default Re: battery light on (WILLFUTHEGREAT)
Try this, pull the battery terminal while the car is running. If it stalls, it's most likely your alternator going bad.
Also, check the harness plug that plugs into the alternator. It may have come loose.
Old Mar 13, 2006 | 06:45 PM
wrx'n you's Avatar
Default Re: battery light on (AndyD)
ahhh....found out the problem, turns out my alternator belt flipped over so the smooth side was on the pulleys. how the hell does something like that happen? lol but its cool though, fixed and done.
Old Mar 13, 2006 | 06:46 PM
M2B4's Avatar
did you win? lol
slickrc
Dec 29, 2009 02:24 PM
89edcivic
Sep 26, 2009 02:38 PM
bleedblue94
May 20, 2006 07:57 PM
fe519
Sep 23, 2003 03:25 AM
