Clearing Codes
Old Mar 14, 2006 | 10:37 AM
sergei_sh's Avatar
Default Clearing Codes
On my Sh i got some water in my intake so the check engine light came on. I got Code 9. I dont really know what it is but the car seems to be running fine. I took the batery cable out for like ten minutes and it cleared the code for 30 minutes and then the check engine light came back on. How can i clear the code and what is code 9? Any help would be great.
Old Mar 14, 2006 | 10:58 AM
Tszyu1's Avatar
Default Re: Clearing Codes (sergei_sh)
Code 9:
Cylinder Position Sensor
Intermittent Interruption
No Signal
Probable causes:
CYP Sensor
CYP Sensor Circuit
ECM
A more complete list is here:
http://www.hondaprelude.to/art....html
Old Mar 14, 2006 | 11:04 AM
AnthonyG2003
Guest
Posts: n/a
Default Re: Clearing Codes (Tszyu1)
To reset it you just disconnect the hot wire to the battery and let it stay off for about 5 minutes right? What all with this reset?
Old Mar 14, 2006 | 11:11 AM
Tszyu1's Avatar
Default Re: Clearing Codes (AnthonyG2003)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AnthonyG2003 &raquo;</TD></TR><TR><TD CLASS="quote">To reset it you just disconnect the hot wire to the battery and let it stay off for about 5 minutes right? What all with this reset?</TD></TR></TABLE>
An easier way to do this is to pull the ECU fuse for a couple of minutes. This also keeps you from having to enter your radio code if you still have the stock radio.
Tszyu1
Old Mar 14, 2006 | 11:14 AM
AnthonyG2003
Guest
Posts: n/a
Good point!!!
pricey2010
May 5, 2010 11:33 AM
Powered By Garrett
Dec 17, 2005 04:55 PM
billyhoe
Oct 17, 2004 08:58 AM
90SiHatchbk
Jun 5, 2004 09:21 AM
turbogsr13z
Apr 8, 2002 11:58 AM
