H22 starter installation HELP!!
Old Mar 11, 2006 | 09:01 AM
crj_lll's Avatar
Default H22 starter installation HELP!!
Ok, here is the deal. My starter went on me. I went to honda and got a remanufactured one. When I put it in, I got a a clicking sound and the engin did not turn over. The battery was 5 years old so I figured it was dead after sitting for a few months before I replaced the starter. So I go out, get a brand new battery and put it in. Now I still get the same clicking noise and the engin does not turn over. I checked the one electrical connection to the starter. Am I missing anything? I get power to the dasj and other systems. Just will not crank at all. Any ideas?
Old Mar 11, 2006 | 09:09 AM
The Weather Man's Avatar
When you take out the starter, just replace it as normal. Anytime you hear a clicking sound - its the starter solenoid. You won't have to worry about the flywheel or anything. make sure you have it tight.
Old Mar 11, 2006 | 10:38 AM
i_kick_turtles's Avatar
Default Re: H22 starter installation HELP!! (crj_lll)
Before you put the new starter on, make sure you clean away all the dirt so it bolts on flat.
Old Mar 11, 2006 | 10:46 AM
crj_lll's Avatar
Default Re: H22 starter installation HELP!! (I R Tylor)
Thanks
The problem is the new starter is in already and I am still hearing the cliking noise. Is there a way I have not hooked the starter up correctly? Also, I just noticed that my power door locks are not working when the car is not on but the lights on the dash board light up. Does one have to do with the other??
Old Mar 11, 2006 | 03:01 PM
92hondalude's Avatar
check your battery.
mine clicks when the battery it realy low
Old Mar 11, 2006 | 03:06 PM
crj_lll's Avatar
Default Re: H22 starter installation HELP!! (92hondalude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 92hondalude &raquo;</TD></TR><TR><TD CLASS="quote">check your battery.
mine clicks when the battery it realy low </TD></TR></TABLE>
THanks. I have a new battery in it.
I fixed it. Loose connection, I think
old-sk0ol
May 12, 2010 12:41 AM
notquitedwight
Apr 25, 2010 03:50 PM
Touge Tuning
May 3, 2006 11:14 AM
92hatchy_7
Feb 23, 2005 01:27 PM
Goy091
Jul 7, 2002 06:09 AM
