Cooling fan problem
Old Mar 16, 2006 | 09:16 AM
95hondaprelude's Avatar
Default Cooling fan problem
my cooling fans are not switching on i replaced the thermostat and the switch and the sensor and my engine still over heats adn the fans dont turn on they only turn on when i put the AC on can anyone help me out what could be the problem i bleed the system and the fans still dont turn on could it be the water pump?
Old Mar 16, 2006 | 09:41 AM
mrOswaldIII
Guest
Posts: n/a
Default Re: Cooling fan problem (95hondaprelude)
what about your fuses? did you check those, look in the engine bay for the fuse box.
Old Mar 16, 2006 | 11:03 PM
Default Re: Cooling fan problem (mrOswaldIII)
fuses are fine
Old Mar 17, 2006 | 06:45 AM
Altilude's Avatar
as far as i remember, on the h22a (non jdm variants) there are two switches - a switch A and a switch B (jdm h22a's just have a switch A) - Switch A is located in the thermostat housing (perhaps the one you replaced?) and switch B is located in the rad hose housing on the front of the engine to the left of the headers.
Switch A - only activates the FAN when the ignition switch is ON
Switch B - activates the FAN when the ignition is off.
unplug the wiring to the switch(s) and jump it (with a piece of wire or something) to see if you can get the fan to switch on - if not you most likely have a prob with the relay, or perhaps the fan itself is kaput. keep in mind - you switch A won't activate anything if you jump it while the ignition is off, but switch B should be able to activate the fan.
hope that helps - all i can remember for now
Old Mar 17, 2006 | 09:12 PM
Default Re: Cooling fan problem (Altilude)
thanx for the info did that fans are still good got new switches still nothing i think im going to have to switch the module
Old Mar 17, 2006 | 11:21 PM
M2B4's Avatar
power to the wires?
200
Old Mar 18, 2006 | 09:33 PM
is there a sensor just for the temp guage or a module that turns on the fans if so where is the location
Old Mar 19, 2006 | 05:20 PM
Altilude's Avatar
for the sensors.
the cooling fan module is next to the ecu on the passenger side. but i see some other folks answered that for you in another post...
good luck - let us know how it works out.
Old Mar 19, 2006 | 05:55 PM
Altilude's Avatar
Default Re: Cooling fan problem (silverlude15)
haha yea.. i realized later - this picture is from an old thread of mine, titled "official bogging and hesitation thread" - and yea you are right - jdm h22a's don't have that extra switch.
Old Mar 20, 2006 | 10:13 PM
thanx now my car up and running woot after 2 months of just sitting thanx for the help
Mitchell A.
Jun 5, 2016 02:16 PM
LukieLuc
Jun 12, 2007 05:46 AM
H22a T13
Sep 28, 2005 10:31 PM
Du_Ma
Jun 14, 2003 12:19 PM
