shift cable
Old Mar 11, 2006 | 10:19 AM
H22A4Me's Avatar
Default shift cable
i was driving the other day and i slammed my car into 3rd gear really hard....now i think my shift cable got stretched and when ever i put my car into 1st 3rd and 5th it goes into gear but i can push futher forward than normal and it is a little harder to place in to those gears....2nd 4th and reverse are fine
went to honda the price of a new shift cable it's $320
Could i fix the cable itself or could it be another problem...?
Old Mar 11, 2006 | 12:39 PM
K-Spec's Avatar
Default Re: shift cable (H22A4Me)
Did you check your shifter console to see if that was damaged? You should be able to find shift cables for $200.
Old Mar 11, 2006 | 03:50 PM
h22chilton's Avatar
* B A N N E D *
the cable its self can not be stretched, no. check the tranny, top side where the cables actually connect, and check the cable for it being aligned all the way on the rubber washer, or a missing cotter would allow it to move, this used to happen to me plenty on hard 3rd shifts due to small cotter pins the ring on the shifter could slide over, leaving the washer intact.
Old Mar 12, 2006 | 01:05 PM
H22A4Me's Avatar
Default Re: (h22chilton)
should i replace it or take it to the shop
Old Mar 12, 2006 | 01:35 PM
H22A4Me's Avatar
Default Re: (H22A4Me)
i think it might be missing a cotter pin i think it is white.....can i replace the cotter pins or do i have to buy a new shift cable?
Old Mar 12, 2006 | 01:54 PM
K-Spec's Avatar
you can pick up new cotter pins, they're dirt cheap.
Old Mar 12, 2006 | 01:55 PM
h22chilton's Avatar
* B A N N E D *
if you are missing a cottor pin then replace it, straighten up the cable/ringend and go see how hard you can hit third!
Old Mar 12, 2006 | 02:16 PM
4bidden's Avatar
It sounds like you popped off one of the large e-clips that secure the shift cables to a bracket up by the transmission. Check that.
spikey0123
Nov 17, 2011 06:51 PM
1stgenboost
Honda Civic (2001 - 2005)
Mar 3, 2009 03:10 PM
Bottledh22
Jul 11, 2006 05:13 PM
ej1 pilot
Apr 9, 2006 06:23 AM
ChrisRicketts
Feb 1, 2005 02:41 PM
